Wheels Locked Up!
Posted 13 September 2010 - 02:55 PM
Any ideas? I suspect a diff issue, but any words of wisdom would be appreciated.
Posted 13 September 2010 - 03:04 PM
Posted 13 September 2010 - 03:05 PM
Posted 13 September 2010 - 03:15 PM
Posted 13 September 2010 - 03:16 PM
Posted 13 September 2010 - 06:03 PM
I've just done that, the wheels turn opposite ways as they should when turned, however they have a lot of slack and the rotation feels a bit rough/bumpy. This was in neutral. Any ideas?
Posted 13 September 2010 - 07:41 PM
If you mean the wheel opposite turns the opposite way ... that's the diff planetary gears doing their job.
Posted 13 September 2010 - 08:10 PM
Yep, that's why I said "as they should". Weird problem, I guess I'm just going to have to rip it apart and see what's going on.
Posted 13 September 2010 - 11:52 PM
Posted 14 September 2010 - 12:21 AM
After scratching my head I reckon it would take 2 full turns of one road wheel, with the other on the ground, to turn the crown wheel once.
Posted 14 September 2010 - 02:32 PM
Before you take anything apart, put the front back on stands, apply the brakes, and quickly get out and try to turn the wheels. If the wheels feel locked up after this, and if your car is older, consider replacing the flex lines to the brakes on each wheel. Old hoses can collapse on the inside and still look good outside. This creates a check-valve situation which keeps the brakes locked on until the pressure slowly bleeds out.
I can tell it definitely isn't the brakes as you can see the engine move when it gets to the end of the available travel, so the thing that's locking the wheels is definitely at the engine end.
The slack could be in the CV joints but you would see that by watching if the pot joints with the wheels. The "locks after one wheel revolution" does suggest the diff, but it can't have totally fallen to bits if the bevel gears will turn the opposite wheel.
The thing is, during the "slack period" the pot joint on the side I am rotating is still moving, so the CVs are sound.
I hope the rain keeps away this weekend.. time to do my 3rd engine removal in as many months.
Posted 14 September 2010 - 02:49 PM
Posted 14 September 2010 - 02:54 PM
Cheers for the help
Posted 21 September 2010 - 07:05 PM
Just had the engine off the gearbox, it's the usual suspect of a snapped diff pin! I reckon if I'd been going any faster the housing would've exploded. Time for an X-Pin diff
