1380 Blow Through Vids Now On Youtube
#16
Posted 07 September 2010 - 01:30 AM
#17
Posted 07 September 2010 - 12:56 PM
can you explain to me how you set up your fuel regulator / carb, i have the same type but i cant work out where they all go. one on right is fuel in bottom left fuel out to carb. top left does this go to vac? and where does the one on the underside of the unit go?
cheers andrew
#18
Posted 07 September 2010 - 03:26 PM
#19
Posted 07 September 2010 - 10:02 PM
And then along to the Mannington roundabout? Happy memories.
Edited by Teapot, 07 September 2010 - 10:06 PM.
#20
Posted 08 September 2010 - 06:09 AM
#21
Posted 08 September 2010 - 10:07 AM
many thanks andrew
#22
Posted 19 September 2010 - 06:47 PM
Andy, pm me your email address and i will try and get some pics over to you. i will be at the castle combe day on sunday if want to take a closer lookcheers mate some photo's could be usefull if at all posable, of the connections to the carb as well.
many thanks andrew
#23
Posted 19 September 2010 - 08:33 PM
many thanks andrew
Its Saturday mate... I always make the same mistake..
#24
Posted 19 September 2010 - 09:14 PM
#25
Posted 19 September 2010 - 09:24 PM
#26
Posted 19 September 2010 - 09:26 PM
Just got possession of a delivery mileage charger so looking to get minx's done for her asap.
How do you find the output of that alternator? Does it give enough juice to run everything because i thought bike alternators needed higher revs for a decent output.
Also what intercooler, dump valve, and bottom pulley did you use? Your setup looks exactly like the way i am going, and i was thinking of an mpi bottom pulley and waterpump pulley to match the supercharger. I'm guessing your using megajolt?
If i can be cheeky, could you message me some more pics of your setup, and a brief account of any issues i get to look forward to.
My emails [email protected] but dont tell anyone, its a secret
Edited by Darkscamp, 19 September 2010 - 09:56 PM.
#27
Posted 19 September 2010 - 11:41 PM
#28
Posted 20 September 2010 - 06:48 AM
#29
Posted 20 September 2010 - 10:53 AM
If we're talking about the same pressure regulator used on Turbos the pipes are arrowed:johnnysti
cheers andrew
Fuel in on the right
Fuel return on the bottom
Carb connection on the left under the boost sensing one.
#30
Posted 20 September 2010 - 07:31 PM
Edited by Darkscamp, 20 September 2010 - 07:32 PM.
