Getting Annoying, Why Won't My Car Start When Cold?!
Posted 30 August 2010 - 09:45 AM
Its a new battery so no problems there, the starter motor just continuously wurrs round and round.
Checked all the sparks and they are fine and the car runs fine once started.
Also I know the engine is probably flooding due to such a drawn out start but there has to be something thats causing this?
I am aware I need some rolling road time, but will this really potentially solve this problem or should I be looking elsewhere?
Posted 30 August 2010 - 11:11 AM
Once again I have gone out to start the mini and the battery has gone flat before the engine started.
Is the choke working correctly?
Posted 30 August 2010 - 12:07 PM
You tried taking the starter off and checking it in a vice that it moves nice and freely?
Posted 29 October 2010 - 08:58 AM
You say the starter just whirls slowly?
Choke is working fine and the the starter motor seems ok too. I don't understand how once I eventually get it started it will go the whole day without a problem, even if parked for several hours it will start first time.
If anyone can help I would really love you forever as this is getting me depressed
Posted 29 October 2010 - 09:01 AM
does jump starting it help? if so possibly a battery/earth issue
spray some quick start or starting gas in the filter and see if that makes a difference?
double check that the jet is being pulled down when the choke is pulled. i spent ages stripping down my electrics and carb, only to find that the connecting lever wasnt working....sigh
Edited by finch661, 29 October 2010 - 09:04 AM.
Posted 29 October 2010 - 09:23 AM
Posted 29 October 2010 - 09:30 AM
Edited by miniman retford, 29 October 2010 - 10:39 AM.
Posted 29 October 2010 - 09:40 AM
because when the weather was like this for me the mini would not start and all it was, the previous owner had not mixed anti freeze in his rad water so that it froze the water and the engine would not start because it was so cold that that it was really hard for the engine to turn over could be something to look at i was really surprised when it worked with mine
Posted 29 October 2010 - 09:48 AM
Posted 01 November 2010 - 08:53 AM
Posted 01 November 2010 - 08:59 AM
Ok so I have been checking all the electrics and when I tried the jump starting trick it did start the car up, I think that perhaps it is a problem with the petrol getting to the engine? Maybe the fuel pump is slowly failing. Does this seem likely/possible?
Surely if that was the case, jump starting it would make no difference to the problem, as your not using the fuel pump from the other car, just the power of the battery.
You can check the fuel pump by taking the fuel pipe off at the carb, putting it into a jug/container and then cranking the engine, preferably with the coil disconnected so the engine doesn't start.
Posted 01 November 2010 - 09:04 AM
start to narrow it down = look for the two main things, FUEL and SPARK
First check that there is fuel in your tank, and in the float chamber, also make sure that the choke jet is being pulled down
second check you're getting a spark. take the HT lead coming out the the coil and place it on the block. crank the engine and look for a spark. if there is a spark, replace the lead and repeat the test for the 4 HT leads. if there is no spark, then check that your getting 12V to the coil!
If you have fuel and a spark, crank the engine. if the starter spins and doesnt fire, take one of the spark plugs out and see if its wet/has fuel on it (you'll determine if there is fuel getting in)
if the starter turns very slowly, charge the battery up and try again. if it still happens after a charged battery, suspect bad earths.....
Posted 01 November 2010 - 09:13 AM
if the jump starter worked, it suggests that your battery is suspect! If it was an earthing problem, then the car would still struggle with starting (slow starter), this all depends of where you attached the jump starter neg lead (body or battery terminal). It was a fuel issue, then the car might not start at all. check your float chamber for fuel (though usually the float chamber remains full for a few days!
I was thinking that if it was an electrical problem and maybe connected to fuel, then as the fuel pump is electric maybe that was whats wrong? Choke is working fine, sparks at every plug and the plugs do seem wet, also battery has alot of energy before running out.
Maybe I should check the electrics on the fuel pump? It does seem to be better if I really pump the accelerator before trying to start the car..
Thanks for the responses
Jordan
Posted 01 November 2010 - 09:56 AM
Posted 01 November 2010 - 10:25 AM
First of all I don't use my Mini very often and up until recently it had been stored in my in-laws garage and evry time I would visit I would try and start it, I quite often struggled but put it down to not much use.
When I brought it home this summer I got it a brand new heavy duty battery (can't remember what one off the top of my head, it was recommended on here of the Mini Cooper Forum) this seemed to work ok. But for a long time it has always been slow to turn over, I put this down to it been a 1380 with high compression (think I got it wrong).
Anyway recently it completely died, would even turn over, just clicked so I went a bought a new starter soliniod from Mini Spares and I was hopeful that this would resolve my problem, because if you look at the mini spares description of the part it does mention slow turning over.
Now it turns over fine and even started on a couple of the very cold mornings we had recently, the part itself only casts £7-£8 so it might be well worth a try.
It seems to have resolved my problems, hope that helps
