Smiths Gauge Refurbishment?
Posted 26 August 2010 - 02:13 PM
Anybody know of the best place or person to send it too?
Also i might need a amp meter checking too.
Posted 26 August 2010 - 02:21 PM
JR
Posted 26 August 2010 - 02:31 PM
Hi all i have recentley picked up a smiths battery condition gauge that needs re calibrating and restored.
Hi Nick,
Why do you think the volt gauge requires calibrating? Does it read low/ high? My experience of these is they work or they don't. Regarding the amp gauge; it is not advisable to fit these to modern alternator cars, due to the large amount of current output going through the cables that would be running through the bulkhead to the gauge. A volt meter monitors the electrics, with the benefit of low current drawn.
Regarding the restoration of the volt gauge, what is actually required? If the black face of the gauge is in good condition, a strip down, clean and polish bring these up a treat. I re-con gauges and sell them on ebay, if you wanted me to do it i would charge around £10+P&P. This would involve a complete strip. grind out all rust on the case & repaint, and a clean and polish of glass and bezel. A picture of the gauge would indicate how much work is required. PM me if you want.
Ryan.
This is a vacuum gauge i did recently:
Edited by L400RAS, 26 August 2010 - 02:33 PM.
Posted 26 August 2010 - 02:38 PM
Hi Nick,
Ryan.
You sound like the guy i need!
I have fitted the Amp meter into the lighting circuit so it shows me if i have the sidelights on during the day
The volt meter is reading too high and needs a through clean and the rust removing and polish the bezel is in good condition on both of them.
Also i need a light bulb holder for this one too not the screw in one but the bayonet type.
Woll take a photo of them now for you
Edited by nick217, 26 August 2010 - 02:48 PM.
Posted 26 August 2010 - 02:52 PM
Posted 26 August 2010 - 04:39 PM
EDIT: by the way, before you assume the gauge is out of calibration, use a couple of additional multi-meters to confirm that the panel meter on your power supply is accurate.
L400RAS, that is a really nice looking vacuum gauge. Nice work.
Posted 26 August 2010 - 05:06 PM
I have an issue, I dropped my Vaccum gauge the other day, and it has broken...
The needle has moved to around a quarter of the way round, and just sits there it never moves. I was wondering what is most likely to have broken, and if it possible to repair it?
Alastair
Posted 26 August 2010 - 05:50 PM
Posted 26 August 2010 - 06:13 PM
Nick, if you are comfortable that the power supply is correct, you may want to attempt calibrating this yourself. On the back of the gauge you will find either two little cork disks covering holes with "screwdriver slots" in them... or if the cork is gone you will just find the holes with screwdriver slots. I believe one of the slots is used to adjust the zero reading of the gauge while the other adjusts the span. If you paint mark the back of the gauge before you start tweaking the adjustments you will have reference settings to return to if your attempts at adjustment are unsuccessful.
See this link for a bit more information and an advance look at what is inside:
http://www.mgb-stuff.org.uk/fuel.htm
The link is for a fuel gauge link but the insides and calibration method will be the same.
Posted 26 August 2010 - 06:15 PM
As the needle is no longer moving, either it has lost its "grip" on the spindle - a dab of superglue... or more fatal, the internal pressure thingy has got a leak, and i don't know how to repair this. I take it hte needle does not move when you suck on the union? - face a mirror to test if you are on your ownAhhhh, I'm glad this has come up!
Alastair
DKLawson beat me to it !I can conform that the power supply is correct voltage.
Edited by L400RAS, 26 August 2010 - 06:17 PM.
Posted 26 August 2010 - 06:40 PM
Posted 26 August 2010 - 08:33 PM
To set your mind at ease, adjust the power supply in 1 volt steps between 11V and 15V. At each setting, allow the volt gauge to stabilize and record what it says. You will end up with 5 known input voltages and 5 displayed gauge readings. Armed with that you can tweak the zero and span slots on the back of the gauge until you get "accurate" readings between 11V and 15V. That way you will know that the gauge is operating properly and is in calibration.
Posted 26 August 2010 - 08:55 PM
Posted 26 August 2010 - 09:06 PM
Cheer's for your help guys.
Posted 26 August 2010 - 10:43 PM
Nope no movement!!As the needle is no longer moving, either it has lost its "grip" on the spindle - a dab of superglue... or more fatal, the internal pressure thingy has got a leak, and i don't know how to repair this. I take it hte needle does not move when you suck on the union? - face a mirror to test if you are on your ownAhhhh, I'm glad this has come up!
AlastairDKLawson beat me to it !I can conform that the power supply is correct voltage.
greeaaaattt! I will source a new one, and put the other one on the bay its face is perfect as is the chrome and bezel!
