Ah, not that I remember the conversation, crumbs I can't remember what I was doing 10 minutes ago any more... lol
but, it's certainly not a 1300GT box, it's from a small bore motor, eg 998 and 3 synchro, as said above it's been opened out to enable the fitting to a large bore or long stroke motor and the 'welding' is where too much metal was taken out and had to have some extra welded in...
the 22G68 case was fitted to the cooper and also all mini 1000's using the remote, before the introduction of the 4 synchro remote in the late 60's
Condition wise it the gearset seems to be in fairly decent nick, you can usually tell how well, or badly, a 3 synchro has been treated by the wear on the layshaft small end and the 1st/2nd synchro ring.... this still seems to have most of the point's on the teeth left which means it hasn't been rammed into 1st very often.
Need's a good clean.
LOL, many thanks for the info. I did call you between Xmas and New Year and you seemed rushed off your feet so no wonder you don't remember.
It's good to know that 1st gear looks OK as the box was reportedly out of a grass-track racer and may have had a hard time. Do you think it would sell better as a complete unit with the Salisbury or would it sell easier with the diff and final drive split from the box? Also, do you have any idea how much it would be worth, it has a 14/63 – 1:4.5 (I think) final drive and I also have a set of Hardy Spicer couplings and the remote housing as well?
