![Photo](https://www.theminiforum.co.uk/forums/uploads/profile/photo-thumb-16530.jpg?_r=0)
Rotisserie Spit Building
Posted 25 August 2010 - 11:57 AM
Where have other people got theirs from?
I was goint to use a scaffold pole for through the car and build the end frames myself I just dont know where to get the pole without buying a brand new one (which I dont really want to do). Anyone got any advice?
Posted 25 August 2010 - 12:26 PM
![:D](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/smile.png)
Posted 25 August 2010 - 12:36 PM
Posted 25 August 2010 - 02:01 PM
Posted 25 August 2010 - 02:44 PM
Posted 25 August 2010 - 04:07 PM
£16 doesn't sound to bad if its a new one though
Posted 25 August 2010 - 05:47 PM
Posted 25 August 2010 - 08:50 PM
Posted 26 August 2010 - 12:38 PM
If you would like some pics of mine I can put some up for you to look at ?
This thread link will show you mine but I have several detailed photy's.
http://www.theminifo...howtopic=166694
Posted 26 August 2010 - 02:16 PM
Posted 26 August 2010 - 05:04 PM
The rear bracket for was made from an Austin A30 Rotodip blank which is metal and exactly the same shape and angle, hardly surprising with the old BMC (later A35 were cardboard as are the mini ones) as the Mini was to replace the A35. The front is a diferent angle and position, in the pic of under the bonnet you will see some bolts, I am to make two cross plates to clamp the inner and outer together as I don't like the idea of relying on 4 small set screws.
Any Questions just ask
Some Photy's
Posted 26 August 2010 - 05:40 PM
not too clear in these pics but it's a lot more solid a way of mounting it on a spit.
![Posted Image](http://i603.photobucket.com/albums/tt112/s8ight/red%20mini/IMAG0189.jpg)
![Posted Image](http://i603.photobucket.com/albums/tt112/s8ight/red%20mini/IMAG0202.jpg)
Posted 26 August 2010 - 07:39 PM
Having said that, I do agree your front mount is a good one but you have no rear bulkhead to mount on anyway. That is a fair idea accross the shock mounts as long as you have strong wheel arches.
I made mine with no reference to anything apart from knowing the factory used the rotodip holes for painting, its nice to see other ideas as mine are not set in stone, I like to think I live life with an open mind.
I have an Austin A35 Van to restore soon and will take onboard yours and other peoples ideas to make a conbination of the best methods.
Posted 28 August 2010 - 09:54 AM
Can anyone tell me how much a completely bare shell actually weighs and what is the minimum height the centre pole needs to be so it rotates clear of the floor??
Posted 28 August 2010 - 12:39 PM
Not sure of the weight of the shell but mine still has doors, glass and other bits still on it and is fine.
My pole is at 40 1\2 inches or 1030mm, which gives about six inch floor clearance when the sill is near to the floor. You could have less if you wanted, I set mine high as the next to go on it will be an Austin A35 2 door saloon which is a little taller.
Hope this helps.
