Barney Cooper
#91
Posted 30 September 2011 - 09:20 PM
#92
Posted 30 September 2011 - 09:30 PM
And a holiday to yorkshire eh? Shame my car isn't taxed or MOTd!
#93
Posted 01 October 2011 - 10:27 AM
Have you managed to find a welder ? And if u have one , when u get back grom uni , get practising man , as so many others have aaid you will pick it up real fast ,
All the best with the car dude
#94
Posted 01 October 2011 - 02:24 PM
Thanks for looking sonikk. I might be able to come up with something with all the damaged stuff I already have and some seal sealent.
Hi mate,what can i say? This is my first post as i have only just joined the site,but i have to say that that i am a professional welder/ Restorer (Classic Cars) and after seeing what you had done to your car that laughingly passes for Welding and plate making I'm totally blown away. All i can say is don't lose heart because for every A..Hole out in the world there is a thousand good Guys that will help you. If your ever in Sunny (well at the moment) Essex i would be more than happy to show you how to weld and give you advice.
#95
Posted 02 October 2011 - 10:03 AM
Just red your whole thread aftrer noticing your thread on south wales minis , I really feel for u man , I'm in the same boat as you, but my car has an mot and I can't drive it lol ,
Cheers, I will do. I'm hoping to replace the front end myself in a year or two, see how it goes.
Thanks, I appreciate the sentiment.
#96
Posted 08 October 2011 - 12:39 PM
#97
Posted 08 October 2011 - 06:03 PM
#98
Posted 08 October 2011 - 06:32 PM
Good on you for sticking with it.
#99
Posted 08 October 2011 - 07:51 PM
Sounds like the car is going to be in good hands soon
Really, really shocked at that so-called welding, the guy that did that needs shooting. As said, the car looks pretty good apart from the (pretty localised..) holes. You'll be bombing around in it again in no time!!
Cheers. I hope so!
#100
Posted 09 October 2011 - 06:35 PM
Picked it up today and after a few trailer related mishaps(tyre blowout and the winch snapping) its in my recently tidied garage.
Had a quick look around and its better in some areas and worse in others!!
Floors don't look too bad, on one side it has 1/2 an oversill fitted!!
The other has a full one, the inner sills don't look too bad and should repair.
The front floor will need a new section to replace the butchered job done to it before
The rear floor needs a few sections let in
The rear 1/4 needs a few repairs to the top and bottom.
Its the boot that needs the most work, its pretty much shot!!
Both arches need extensive repair, I'm hoping to only have to buy one arch and use that as a donor panel for both arches.
The rear valance has been fitted very badly, to do a proper repair on the boot floor this will need to be removed so replacing it is no hardship.
I should be able to keep the panel list quite small as I've got various off cuts that can be used.
Watch this space!!
#101
Posted 09 October 2011 - 06:38 PM
#102
Posted 09 October 2011 - 08:02 PM
Seeing that pic has confirmed it for me really!!
#103
Posted 10 October 2011 - 12:00 AM
#104
Posted 22 October 2011 - 07:08 PM
Up on stands so cutting could commence!!!
Pulled off the over sill on the drivers side..........oooopsss!!!
Thats a bit worse than I'd have liked, still onwards and upwards!!
Cut and fitted the new front floor section
The inner sill needed quite a few repairs and to be honest it was borderline on needing a new floor pan but I know Daves on a budget so
I repaired it.
Nearly finished it..
That looks better!!!
Still got 1/2 a day left on this side and its done.
Stay tuned!!
#105
Posted 22 October 2011 - 07:10 PM
