1960 Morris 850 And Friends
417 replies to this topic
#121 minimuk
minimuk
  • 1,946 posts
Posted 18 December 2011 - 09:54 AM
Chris, who is shirley, she doing a project on here too?
#122 CLM
CLM
  • 817 posts
Posted 21 December 2011 - 01:58 AM
A bit more work done the last couple of days, I managed to peel the last of the inner sills out and clean off the remains of the floor extension piece.
I found a couple of curious triangular sheet metal pieces at the door corners, I'm thinking this is a "mk1/2 Wagon thing" and I should put them in the van when I convert it to this load floor. I dont think I will need them with the commercial style load floor.
After that I removed the crossmember and the floor sections along the toe board from the tunnel of my original car... and just could not resist offering it up to the wagon... what do you thing? Heh
I Will call m-machine tomorrow if I havent recieved the shipping quote by then, I really need to get the floors on their way. But untill they arrive I will have plenty to occupy myself with, there is still a few sections of the tunnel that need attention, and some triangle pieces to remove!
Untill Next time,
Chris
#123 L. Brown
L. Brown
  • 22 posts
Posted 21 December 2011 - 02:55 AM
it's a mid 65 shell, in the 700k
#124 CLM
CLM
  • 817 posts
Posted 21 December 2011 - 03:15 AM
Hmm, it had to have been revinned at some point, Or had the front panel replaced, the front panel is definitely a mk2/3 item., The holes for the later style grill trim are stamped and not drilled. Doesn't make much difference though it's still being modified beyond recognition heh :)
Oh and just because I can't seem to go out there without messing with things...
Oh, Hey lance, did you sell those tinny side frames? Been thinking of leaving the sides as is for a while as I collect the other pickup bed pieces. And might just toss some plexiglass sides in the window holes for a while.
Chris,
#125 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 21 December 2011 - 06:46 PM
Chris man I'm weeping and its not manly. That makes my Mini look perfect. I wish you the very best with this.
Hugh
#126 L. Brown
L. Brown
  • 22 posts
Posted 21 December 2011 - 08:46 PM
Car is original right hand UK car, I'm sure it was patched before it came here in the 80's
yes I have the side frames still as well as a headliner and backseat
#127 CLM
CLM
  • 817 posts
Posted 21 December 2011 - 09:05 PM
Hugh
I know what you mean Hugh, makes me want to live on the other side of the pond! D:
I will probably work out a deal for those window frames later Lance, I do need to do the floor first though... For obvious reasons!
Chris
#128 CLM
CLM
  • 817 posts
Posted 23 December 2011 - 11:42 PM
Just a quicky, got the panels ready for the trip up John. When trying to remove the center of the crossmember I ended up putting another couple of slits in the bulkhead. It should be nothing to weld those up. I also welded a bar between the ends of the the crossmember so the subframe mounts should not move in relation to each other. Talk to you later.
Chris
#129 johnsn
johnsn
  • Just Joined
  • 69 posts
  • Local Club: OMS
Posted 27 December 2011 - 08:44 PM
Chris
Looks good Chris,
I work 7AM to 3:30PM in Wilsonville.
I'll send a PM with other phone #s, and address.
john
#130 CLM
CLM
  • 817 posts
Posted 04 January 2012 - 09:49 AM
Quickie update, order placed with M-Machine;
left and right saloon length bare floor pans
left and right saloon/wagon heelboard repair ends with subframe mount brackets
left and right van/pickup inner sill stiffener
heritage garages lwb floor extension
one van/pickup subframe closing panel that I will use as a pattern to make a second... the van's closing panels are butchered bad for copying
left and right half moon closing panel segment... as I hate trying to make curved things :ermm:
This should be enough to put floors in that wagon...or pup..err or whatever that rusty thing is on my spit lol
Waiting is torture!
Chris
#131 CLM
CLM
  • 817 posts
Posted 04 January 2012 - 10:55 PM
Just got a reply over on the cooper forum over approximate dating on the FE number still attached over the radiator shroud.
FE1223885 dates to around February 1968.
Which would mean some time in the past it had that vin plate attached to it. It should be an early mk2
Now... Does that really make much difference in the overall scheme of things? Plan is to turn it into a pickup. But rarity wise, how rare is a mk2 steel sided estate? Not that I have anything but a bare shell mind you and a bare shell that is in horrible shape I personally would rather build it into a pickup myself.
Chris
#132 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 05 January 2012 - 09:20 AM
Chris I hope the carriage cost is not too outrageous to get these panels over the Atlantic!! M Machine would be as helpful as they could. I once paid to have a rack for my motorbike sent the other way over the water. It cost more for the carriage!! A good new year to you. Hope you don't have to wait too long.
Hugh
#133 CLM
CLM
  • 817 posts
Posted 06 January 2012 - 12:32 AM
Well quoted delivery cost is £165 which shouldn't be that bad, overall price should come to around $615 or so, about £400 roughly. And a good happy new year to you to Hugh :) Thanks to a recent post I have dug through old photos to come up with a few pictures of my car from days gone by.
In 95 I had just gotten it and mom wanted to take a picture of me with it, she told me to sit on it.... so I did. She used it as the Christmas cards that year!
It looked like this in about August of the next year in '96, after we had welded a new front end on.
I drug it to Nebraska and back and it sat for several years, had driven it a fair amount, then in 2005 Someone working at a coffee shop on my way to work started driving a mk3+ mini to work so I got the urge to try to get it going again, this is as I am digging it out of storage, wirebrushing, and applying more red oxide and peeling the hideous destructive fiberglass off the floor..
That was likely the best it had ever looked since I owned it...
until a wheel bearing disintegrated.. I should have replaced it, but I was trying to come up with disk brake parts and didnt want to replace wheelbearings twice :(
Then we come full circle to the start of this thread.
That is over 15 years of a car that in all rights was not worth repairing in the first place... floors were gone both quarters were beat up the lower rear panel was destroyed, had accident damage on the right side....
Someday I will have a shiny one...
Chris
#134 CLM
CLM
  • 817 posts
Posted 06 January 2012 - 01:17 AM
More old pics here.
http://s1202.photobu...mini/oldphotos/
Chris
#135 minimuk
minimuk
  • 1,946 posts
Posted 06 January 2012 - 10:19 AM
Nice one Chris, like the history behind your mini and the 'never let go' atitude, Happy new yr to you to and hope you have ordered all you need from MMachine. ;D Good luck for this year.
