1960 Morris 850 And Friends
#91
Posted 01 October 2011 - 08:05 PM
#92
Posted 02 October 2011 - 06:54 PM
That left me with the bulkhead and the crossmember, I marked out the areas I am going to need to cut for the van to get your thoughts on it John.
I should cut it right to the bottom of it for the van, but that will leave the remaining pieces somewhat flimsy. If I cut them off before removing the crossmember however I should be able to put some sheet back in there if you would like. I'm not sure, so havent cut anything yet.
Unquote.
Let's see.
Cut from the bottom to above the heater mounts on both sides first.
Then screw a peace of sheet metal that extends over the cuts.
Then cut the rest as marked.
Then if you screw another sheet metal over the speedo hole, you can cut the that strip at the top and transport it in two parts. After you you unscrew the sheet metal.
I can screw it back together and make filler parts.
john
Edited by johnsn, 02 October 2011 - 06:56 PM.
#93
Posted 13 October 2011 - 01:51 AM
after which I cut the whole piece out and removed the spot welds so I could remove it leaving the rest still attached to the crossmember, I then layed it down on a sheet I had traced out and cut myself a replacement, You can keep it or cut it out John, but it's in there for now.
Using a post and some clamps I bent it to the right shape and drilled out the pedal box mounting holes so I could bolt it to the crossmember.
I then started carfully alligning things and tacking them together... the welds on the bottom were not working well, I cleaned the metal down washed it with carb spray and did what I could but eh, not my best welds. The upper ones turned out better but I only tacked them as I wasnt closing a gap like the bottom. I didnt cut out any of the other areas on it, just welded it in as a big sheet more for bracing then anything.
Just need to pop it off of the crossmember now and it's ready to go John, still no eta on the trip up.
Chris
#94
Posted 14 October 2011 - 10:21 PM
I haven't got back to the 1100 yet, but I did find out that I don't need the right hand B pillar. I have one.
Keep up the good work.
john
#95
Posted 21 October 2011 - 02:17 AM
Chris
#96
Posted 12 November 2011 - 01:08 AM
I managed to get the pieces I needed from the motorhome to build a spit, It may still be a little short, but it is easy enough to extend, and it should be pretty stout. The square pole should make having lots of clamps along the pole where the shell will mount pointless. The seat clamps seem to work well for keeping the pole from spinning so far.
Now to make the bits to attach it to the shells.
(yes I know that pole is too short, I have 2 of them so they will be joined end to end)
Chris
#97
Posted 12 November 2011 - 11:44 AM
#98
Posted 18 November 2011 - 01:51 AM
I started today by removing the doors from the wagon shell, and crushing my thumb in the process... it still hurts. The doors are seriously roached but they are being set to the side as I may repair them. I then went and removed the handbrake lever and the little cover plates for where the handbrake cable goes through And went to fitting my door frame jig in there that was originally built in a 1960 saloon... and... surprisingly with how bad things are it lined up and fit in this roached mk2 wagon shell.
I then went ahead and installed my shell mounts I had built in the saloon, wanted to make sure when I had to use it on the saloon it would pass through the spit hole in the rear seat... so I built it there then used it on the wagon easier then building it in the wagon and rebuilding it when it didnt fit the saloon...
The mounts seem a bit beefier then others I have seen pictures of... but... well.. overbuilding isn't bad...
Once I got those in and was able to cut my spit poles to length and through drilled the ends so I could bolt them together I assembled it all, it is actually ready to be set on the frames now... I just ran out of light in the shop to do it tonight.
Oh, thought I would get a pic of the friend I have had visiting daily for the past month or so...
Chris
#99
Posted 18 November 2011 - 07:39 AM
Graham
#100
Posted 18 November 2011 - 08:08 AM
I am actually more worried about the sections that connect the round ends to the square pipe, it's a direct butt weld on the square to round stock with no overlap... those ones in the post from the 11th... which coincidentally has a good picture of the wall thickness considering it is 2 1/2 inch inside square
Chris
Edited by CLM, 18 November 2011 - 08:12 AM.
#101
Posted 18 November 2011 - 11:04 PM
Now we build up a nice fire and slowly rotate to sear in all the juices...
Whew Finally got a workable spit done, it turns like butter with very little pressure, and each of the locks clamp the whole thing tight.. Excellent. Though I do think I am still going to do the safety pins at the ends every 45 degrees from flat. Here's that center mount.
I think it will suffice to hold the poles together and in alignment.
Still a little worried about the ends, but I think they will work. Will likely be the weak point, but still plenty strong.
Next I am going to have to do something about the lack of lights in the shop, move some stuff around so I can move the 850 to the far side of the shop so I can make the shell rotate... then I get to rip that hideous floor out wheeeee.
Chris
#102
Posted 19 November 2011 - 02:52 AM
I am thinking of putting together a couple small shelf units next to the wall where the wagon is, about 3 feet high or so so I can use the top like a workbench.
Tomorrow I need to see if I can get the Honda XR80 to run.
Chris
#103
Posted 19 November 2011 - 07:00 PM
Hugh
#104
Posted 20 November 2011 - 01:44 AM
And thank you
Chris
#105
Posted 20 November 2011 - 08:16 PM
Chris,
If you add some small plates on each side, I think they are called fish-plates, like the attached picture, you'll be fine.
Tell me more about the door jigs?
john
