1960 Morris 850 And Friends
417 replies to this topic
#286 CLM
CLM
  • 817 posts
Posted 16 September 2012 - 05:20 AM
Naw, it still has the plastic wrap on it, too lazy to take it off :P
I have been taking it apart since I got it, I need the engine and subframes off of it like yesterday so I can assess the bottom!
Are you sure you don't need an early1960 Austin 850 John? It even has a title... :P
Chris
#287 CLM
CLM
  • 817 posts
Posted 17 September 2012 - 03:56 AM
Well I have taken large chunks of the moke apart today, happy that the engine ran so well I decided to tear it to bits. I dont think there is one panel on this thing without any rust! Yay Fun! :D
I started out by drilling the rivets out of the mystery plates on the pannier tops.. mooore rust! I wonder if anyone else would even touch this thing heh. The whole bottom of the load floor is covered in scale, that will be fun to clean up.
I still need to get the saloon out of the shop soon. More pictures for all of you.
Chris
#288 L. Brown
L. Brown
  • 22 posts
Posted 17 September 2012 - 07:31 AM
If your were a real hot rodder you'd just paint that beatch with por15. They make putty too you know. Maybe some foil tape or window screen material to reinforce that floor and just runner!!
#289 CLM
CLM
  • 817 posts
Posted 17 September 2012 - 07:49 AM
Now, if I were a real hot rodder... Would I be playing with Minis? :) Now get that pickup done! Or take the 1071 out for a drive.. or excavate the yellow one... or build up your wagon... or fix your Lotus Cortina!
Chris
#290 L. Brown
L. Brown
  • 22 posts
Posted 17 September 2012 - 07:59 AM
Bla Bla Bla soon as I get some garage doors....
#291 CLM
CLM
  • 817 posts
Posted 17 September 2012 - 08:25 AM
Is it my fault you bought a 1071 cooper S instead of finishing your garage? lol
Chris
#292 CLM
CLM
  • 817 posts
Posted 18 September 2012 - 12:43 AM
Lookie what I got in the mail today!
A $1500 box! Fully of shiny(well not actually shiny :P) original panels!
And knowing a normal car guy who likes model kits, I just had to pull it out of the box and try sticking things together "without" glue... trial fitting... (in other words playing with my new toys..)
Look Ma! No rust!
Chris - The Giddy
#293 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 18 September 2012 - 11:48 AM
Nice new panels, Is it easier to fit the panels to the moke or the moke to the panels? O_O
#294 CLM
CLM
  • 817 posts
Posted 18 September 2012 - 05:19 PM
What comes first? The Chicken or the E.. err the Moke or the panels?
I will likely jig up a baseline for my front to rear subframe mounts and build the center tub then introduce the front and back to the built up center after repairing rust on them. Anything is repairable if you throw enough money at it!
I think I mentioned in your thread something about a build your own heritage shell kit, I think this is on par lol.
Chris
#295 CLM
CLM
  • 817 posts
Posted 19 September 2012 - 07:02 AM
I ran into an annoying issue today, my fuel tank has a hole in it, in the side where the pannier cover rusted it >:(
No holes in the bottom, inside is flawless..
But there are holes in the side at about the 2/3 tank level :( I am going to need to find someone who restores fuel tanks to weld a patch in.
Chris - 'hole'y distressed
#296 jagman.2003
jagman.2003
  • 1,307 posts
Posted 19 September 2012 - 07:19 AM
Is the tank Moke specific? Anything like the estate/van version?
#297 CLM
CLM
  • 817 posts
Posted 19 September 2012 - 09:08 AM
Not only moke specific, but specific to early mokes only.
Fun
Chris
#298 johnsn
johnsn
  • Just Joined
  • 69 posts
  • Local Club: OMS
Posted 19 September 2012 - 03:19 PM
Na, just throw some dry ice in it and weld a patch in it.
john
#299 CLM
CLM
  • 817 posts
Posted 19 September 2012 - 10:17 PM
Hmm That makes sense, seems rather mad scientish with the dry ice but makes sense lol
Chris
#300 CLM
CLM
  • 817 posts
Posted 20 September 2012 - 03:58 AM
Greetings all
I started out today by finishing the stripping of the rear subframe which required flipping the moke up on the other side to access the right hand trailing arm setup. Interestingly I found these aluminum plugs in the subframe, I have not seen these before, I bet they would annoy someone trying to use old style allen key adjustable high lows.
Once it was stripped I set it back on the ground so I could start constructing a cradle I could use to attempt to level out any twist that might be in the body, this gave me the perfect opportunity to get an interesting rotten floor shot :) And while I was down there I took a picture of a factory error I found in the front seat mount... do you think I should replicate it? :P
I tossed my toeboard jig in expecting it not to fit, I made it on my 1960 saloon shell earlier if you had seen in that post. Surprisingly it all fit and bolted on easily, even the almost completly rusted out hole lined up perfectly!
Finally, I dont think this is quite right, this Moke has 3 unions in the middle of it's rear brake line, this cant be normal...
Chris
