I then decided I should do something I had been putting off for some reason and I drug out the old rotten floor pan and removed the seat belt anchor and the battery cable guide from it and worked at cleaning them up.
After putting a fair amount of paint and other protectants down I drilled the seat belt holes and welded the sucker on. It had been spot welded in the mk2 wagon floor but the original mk1 cooper floor pan section I have has it seam welded so I seam welded it.. maybe a bit more then the cooper was but I didn't want water to be able to get under it from the front. I also left sections of the back and bottom un welded for drainage if anything does get under it.
At this point I am grinding to a standstill on this project without acquiring some new panels. I will probably get the a panels and scuttle ends next with a battery cable and a couple multi-clips for the floor, maybe toss in some load floor shaped corners for good measure and a heritage closing plate or two if I can get the coin together.
We'll see where we go from here, maybe pictures of the subframe next!
Chris
