Thanks Hugh, not a problem, I have been watching your thread as well and it's looking good even better then mine! lol
I'm looking to see it welded in as well, but I still need to fabricate up the carpet brackets fix the spare tire mount I ripped out of the van. I also need to rip the lower battery retainer bar out of the van and refurb it so it can be attached to the floor before I stuff it in the wagon. I am worried it is going to be as rusty as my spare hold down bracket is.
But it is repairable, and looks good on the new floor
I managed to grind down the big boogery welds that have been there for over 15 years on the back of the tunnel, not looking forward to grinding the long welds though
there is still some holes in front of where the crossmember will go where the auto lever was mounted and where my remote mounted, I will fill those in eventually.
I am probably going to only bolt the back edge of the floor to the floor extension that's there so I can unbolt it and remove the rear floor later, when it gets built up with the correct floor extension it will be.. "properly welded"
Chris
