Mk1 Austin Mini
#46
Posted 05 November 2010 - 09:29 PM
#47
Posted 05 November 2010 - 09:51 PM
#48
Posted 05 November 2010 - 10:06 PM
#49
Posted 18 November 2010 - 01:11 AM
#50
Posted 10 December 2010 - 12:54 AM
Ordered a Maniflow Cooper Freeflow exhaust manifold and a full RC40 Exhaust system. I hope to install it in the next couple weeks and get the Mini running again.
#51
Posted 12 January 2011 - 08:48 PM
Over the last few weeks, I received my RC40 Exhaust System and Maniflow Cooper Freeflow Exhaust Manifold / Downpipe.
The manifold that initially came with my car was an LCB, but we didn't know what kind and it didn't work with my new carb / intake manifold setup. We had used an earlier Maniflow LCB to initially test fit to see if my carbs would be able to clear the exhaust manifold and mount up to the head. It turns out that over the years it seems that they have slightly modified their manifolds enough that the new Cooper Freeflow was not able to fit with my intake manifold. Thankfully Chuck had many extra older LCB's and we found a Janspeed Exhaust Manifold that allowed just enough clearance for everything to work. We struck a deal and exchanged manifold for manifold.
The next problem that showed up; I received an incorrectly matched RC40 Fitting Kit. We had to wait for some parts, and we are still waiting for 1 more part to fully finish the install.
Cutting out the old manifold, as it was so rusted that I couldn't get the old y piece off.
All gone...
New to me Janspeed LCB Exhaust Manifold, Janspeed probably didn't make it and they were most likely just resellers of it.
RC40 Exhaust System, we had to cut down the first pipe as it was made for the Cooper Freeflow Exhaust Manifold. Thankfully that allowed us to push the whole system back a bit and I am pretty happy with the fitment on the rear of the car. It is only about an inch off of where I would want it idealy. Normally it would be about 4-5 inches further in.
That's it for now, thanks for reading!
#52
Posted 18 January 2011 - 10:22 PM
We ran new fuel lines for the new to me / rebuilt twin HS4 carbs, installed a fuel regulator as the Mini has enlarged lines and a larger capacity fuel pump for the old Weber 45, ran the throttle cable and choke cable, removed all of the weird overflow and breather stuff, and got the carbs fitted up. I am hoping that next Monday we can get it started.
#53
Posted 19 January 2011 - 07:43 PM
#54
Posted 19 January 2011 - 08:08 PM
#55
Posted 25 January 2011 - 10:00 PM
I am hoping to be able to bring it home soon after that so I can get the welding / body taken care of. I am really itching to drive it!
#56
Posted 27 January 2011 - 09:40 PM
It is actually a Austin Seven Deluxe, and it was originally Speedwell Blue with a grey interior. It also had the optional heater. As Chuck had already confirmed for me, it was built in July of 1960 and dispatched as an export to the USA. It was then sold in Portland, OR.
I'll get a scan up of the Heritage Certificate when I get a chance.
#57
Posted 28 January 2011 - 07:47 PM
#58
Posted 29 January 2011 - 05:45 PM
Nice job on the mini. I noticed your coil was sitting upright. It should either be pointing down or horizontal. They are filled with oil which helps in cooling the coil. The way it sits now the internal electrode is exposed and will get very hot. The coil has the potential to explode. Sitting horizontal the oil will cover the electrodes keeping the coil much cooler. Just something that was pointed out to me when I was car show from a mini race buddy.
Keep up the excellent work and have a blast!
#59
Posted 30 January 2011 - 02:53 AM
Hey Buddy
Thanks for the tip! I didn't know it had that much of an effect on it, but I was planning on moving it anyways. I will definitely mount it horizontal when it gets moved.
#60
Posted 09 February 2011 - 07:26 PM
We were going to try to take it home on the 6th, but the Mini decided otherwise... After Lis and I checked the valve gap, I took it on a test drive. It got out of Chuck's driveway just fine, but about halfway up the street it started misfiring. It also took me forever to start it still, but once it is warm it starts up just fine. We checked all the obvious stuff, and even switched out the rotor cap, but it was still misfiring.
As of the 8th, Chuck and I were talking over things and he had a theory that a low battery might be the cause of the misfiring as the alternator isn't functional right now. He put it on the charger and even with a partially charged battery we started it up and it seemed like the misfiring issue has been fixed. He is going to fully charge the battery over the next couple days.
Next issue is the hard start and getting the alternator setup right. It seems as though the choke cable isn't fully choking the carbs, with chuck manually fully choking the carbs they seem to want to fire right up.
Edited by buddylove, 09 February 2011 - 07:26 PM.
