Replaced the battery yesterday with a Optima Red top, and found out that half of the floor of the battery box is missing. Yuck. It fired up under its own power though.
Siphoned out the old fuel today and filled it up with 91 Octane from Chevron, its running a lot better and is much easier to start. I was able to get it started without using starter fluid.
It does seem to have some sort of heat soak / hot start issue. I let it run for awhile and then shut it off, then waited a couple minutes and started it again. After that, I shut it off again and tried to start it again with no luck. I then waited about 45 minutes and it started up on the first try.
Here are a few photos of what I have accumulated so far.
Fiberglass flip front that needs some fiberglass love, future project.
Replacement panels and seals from Mini Spares.
Mk1 Cooper S Panels from Pigpen. They could use a good clean, and new backing.
2 Complete Wiring Harness and some other odds and ends from Pigpen.
