Rear Quarter Panel
8 replies to this topic
#1 tucky
tucky
  • 16 posts
Posted 07 August 2010 - 12:00 PM
Hi guys just a quick one my rear quarter on the drivers side lower rear window bit has rotten through i can poke me fingers through her;. I have orderd a replacmeant rear lower quarter section from them blokes at mini sport. Does any know best way of welding these on thanks also do i need a repair panel as such for these too attach too thanks
#2 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 07 August 2010 - 07:54 PM
stick a full quarter panel on, it's quicker and neater than doing one repair let alone two
#3 samsfern
samsfern
  • 5,243 posts
Posted 07 August 2010 - 08:42 PM
just pug it with filler! Job done! Halfords sell filler, if they havent got any in stock, just use fibreglass
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 07 August 2010 - 11:01 PM
Come on, I'd expect better advice off you, we both know thats not the way forward.
I believe that repair panels for this area are now available? Failing that either make one or use a door step panel
#5 100ev8
100ev8
  • 622 posts
Posted 08 August 2010 - 08:40 AM
i repaired the o/s/r 1/4 panel on the sons and will regret it every time i look at the car . the time it took to cut out, prep edge , step new panel , weld in , grind down , fill , primer was twice what it took to replace the complete one the other side
my advice replace the complete panel !!!
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 08 August 2010 - 11:30 AM
There's also a good chance the brace strip will be corroded as well.
If you do go the whole quarter panel route i would defo recommend the Heritage quarter panel as it is a good fit, this will also give you the chance to have a good look inside the companion box for rust and the heelboard close out panel
The brace panel is only spot welded at the front (2 welds if i remember) and at the back ours was seam welded.
#7 tucky
tucky
  • 16 posts
Posted 08 August 2010 - 12:06 PM
thanks guys ill get on and order whole side then do i also need to order a new brace panel as well please ???
#8 tucky
tucky
  • 16 posts
Posted 08 August 2010 - 12:17 PM
basicly its gone under the rear window and has big buble patch where the rust is and unfortunitnly gone all the way through
#9 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 08 August 2010 - 12:47 PM
The waist rail as it is called CZH426 is £34.06 from Somerford, this is a Heritage part.
