Best Rust Remover
Posted 05 August 2010 - 08:57 PM
Posted 05 August 2010 - 09:25 PM
Posted 06 August 2010 - 06:42 AM
Posted 06 August 2010 - 07:17 AM
as title really? whats the best to remove and attack rust before pating? seen loads of different ones in halfords (krust, Genolite etc) what one is best?
http://www.neutrarus...nical-info.html
Gets some impressive reviews; but I haven't used it myself - Minis don't have a big rust problem here in Oz.
About 20GBP a litre.
Posted 06 August 2010 - 08:14 AM
Lucky you!! Ive used th krust stuff which looks like milk n turns blue/black as it reacts with rust n it works really well, but now ive got th krust gel n havnt used it yet so not sure how good it is. Benas title really? whats the best to remove and attack rust before pating? seen loads of different ones in halfords (krust, Genolite etc) what one is best?
Posted 06 August 2010 - 08:42 AM
Posted 06 August 2010 - 08:47 AM
just apply this again once rust shows again lol
Posted 06 August 2010 - 09:15 AM
Posted 06 August 2010 - 09:37 AM
angle grinder
Agreed.
Posted 06 August 2010 - 11:05 AM
angle grinder
Agreed.
I disagree, an angle grinder is the right tool in certain circumstances (i.e. to remove deep or structural corrosion) but if you attack superficial or surface rust with one, then you remove a certain amount of non corroded material as well & therefore unnecessarily thin the metal. Grinding also usually leaves you with a scored or pitted surface that you either have to "fill" (god forbid!!) or cut out and replace with new metal (which is rather unnecessary). Using an angle grinder on all corrosion can be like "using a sledge hammer to crack a nut". Also rust converter/killer is useful to treat areas that you HAVE attacked with an angle grinder as it protects them from further corrosion underneath the new paint.
That said it also needs to be used appropriately, brushing a rust converter onto a rotten panel that needs to be cut away and replaced is pointless and nothing but a waste of rather expensive rust converter.
Posted 06 August 2010 - 03:12 PM
Posted 06 August 2010 - 06:28 PM
i know use por 15 metal ready (think thats what its called) seems to work rather well and it also etches clean metal ready for paint
Posted 06 August 2010 - 06:29 PM
Edited by daniel190, 06 August 2010 - 06:29 PM.
Posted 07 August 2010 - 08:53 AM
use a angle grinder
I refer you to my previous response as above!!
Posted 07 August 2010 - 12:44 PM
As above, used the removing gel and hydrate 80 on my vw van and it still perfect after a year with out even putting any paint on top! Good stuff. Their cavity wax is also good.Hydrate 80 from bilt hamber labs is really good. Used it loads before and it does a great job.
