1979 Rust Heap Clubman Rebuild
626 replies to this topic
#376 rich2
rich2
  • 353 posts
Posted 22 September 2013 - 05:46 PM
Long time no post again. The mini has been firmly on the back burner of late because of the arrival of this guy...
...our awesome son Sebastian, born on 8/9/13!
Before Seb was born though, I managed to get the A panels on. Lip was bent around using mole grips, a rag and a block of wood.
All welded up.
Primer on.
Other side!
DETAILS!
Unfortunately, I may have made a boo boo on the drivers side. I cut out a section of the flitch lip early on in the project because I thought I needed to. I realised just recently (after fitting the A panel) that I think I was wrong to do that because the door hinges now won't fit in the gap. AAARGGH. The A panel may well have to come off again to fix the problem.
I also added some factory-style finishing pieces to connect the A panel to the wings.
#377 rich2
rich2
  • 353 posts
Posted 22 September 2013 - 06:03 PM
While I was working on the A panels, I also tried to put the rear subby together. Everything was gravy until I came to bolt the radius arm brackets on. OH DEAR.
So basically, when I had welded new captive nuts into the subby earlier in the project, I did so assuming the mounting face of the bracket should be flush with the end of the subframe. WRONG! That meant that when the radius arm was fitted the bracket is misaligned. Le sigh.
I didn't want to cut the subby apart again, so I opted for modifying the brackets slightly. This will be a pain if I ever upgrade to cambered brackets because I will have the same problem again. All told though, the subby isn't in the greatest nick anyway, so if I end up doing major suspension upgrades, I might as well just get a new subby.
SO. Cutting disc out...
Weld up again.
Sorted. I did this on both sides. Pictured here with my new-old recon radius arms and retrosport billet subframe mounts.
Bling! New cones and cleaned up trumpets in place, and brand new brakes and bearings fitted. I cleaned up the old hubs as they were fine.
#378 rich2
rich2
  • 353 posts
Posted 22 September 2013 - 06:34 PM
So with most of the body work on the car sort-of finished, I started thinking about the doors.
Didn't take pics because there wasn't much to see, but I dismantled and de-skinned both doors. Then I could see what kind of rust situation I was dealing with. Both door frames needed similar treatment, so here is the worst one...
Bottom edge: FRIED!
Removal to good metal. Kept the corners on for now to keep things simple. One step at a time.
Made up a little repair.
Tacked repair into panel.
Fully welded up.
Had to drill out the hinge bolts as they were rusted solid.
Hmmmm... questionable integrity of metal. Decided to make an exploratory incision.
Oh dear. Decided the only thing to do was to whip the whole thing off.
Yuk.
Made up a suitable repair for the hinge panel...
...and the lip to the door skin.
Welded in.
Other side...
And repeated the process on the lip at the slam end.
Finally, when both frames had been completely rust repaired, I applied rust protection, primed and top-coated the insides. (Shown here in primer.)
Meanwhile, I had ordered up a pair of new heritage door skins.
The insides were roughed up a bit, primed and top-coated. I thought it was best to get some top coat on the insides of the doors at this stage because when the skins go on it will be difficult to get paint into them.
I had considered the idea of purchasing a set of Retrosport billet door hinges because the are trés sexy, and the old hinges from my car look like a dog's breakfast:
However, in the interest of saving cash, and on closer inspection I decided they could be rescued. I stripped the paint and put them in vinegar for a week, then drilled out the broken bolts and welded in new ones. The restored hinges should hopefully be quite serviceable, and I will have saved over £100 :)
#379 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 22 September 2013 - 06:48 PM
Mate many congratulations to you and the boss with the safe arrival of little Seb. Now the dilemma you have a few years to sort the clubby and get building another for your lad.  :D  :D  :D
Nice work with the door and highlights where rust lurks.
#380 skoughi
skoughi
  • 1,200 posts
  • Local Club: Shetland classic car club
Posted 23 September 2013 - 12:23 PM
Congratulations on your new arrival, he looks the bees knees! From the mouth of a father with two sons, the man cave with the mini will be a god send at times! Good work on the clubman by the way. With all the work you've done then there will always be one or two backward steps that have to be taken, as I'm finding out now and then!
#381 hoody99
hoody99
  • 699 posts
Posted 24 September 2013 - 11:52 AM
Congrats on the wee one buddy will be a mini nut soon enough lol . With your radius arm brackets did you not try bolting that side on first and then see how the ones underneath lined up mine are a pig to fit with it all being standard and un modified lol but the way you've sorted it looks great lol
#382 hoody99
hoody99
  • 699 posts
Posted 25 September 2013 - 06:20 PM
Also the bushes on your trunion bolts are the wrong way bud fat end goes to the outside according to the diagram on mini spares
#383 jakub.cr
jakub.cr
  • 50 posts
Posted 09 January 2014 - 08:09 PM
Hello.. any news?
#384 Jase
Jase
  • 1,166 posts
Posted 09 January 2014 - 08:23 PM
I was wondering how you were progressing as wel.
#385 rich2
rich2
  • 353 posts
Posted 11 January 2014 - 07:57 PM
Hi!
I actually haven't touched the mini for months now. It turns out this fatherhood lark is quite time consuming!
Really looking forward to eventually getting back to work on it, but there are just not enough hours in the day at the moment. I did have a quick look in the garage last week and noticed some surface rust forming on the primed floors. Painful to see but not unexpected. There will be more work to do by the time I get back to it, but worst case scenario is I just get the shelled dipped and go from there.
I haven't given up! Watch this space!
#386 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 11 January 2014 - 11:05 PM
Just spent about 2 hours reading through 26 pages to find it not even finished... disappointing :P
But honestly, this was a great read and you certainly progressed from never welding before to fabricating your own repair patches, but now, get it finished :P
#387 minimuk
minimuk
  • 1,947 posts
Posted 12 January 2014 - 08:55 PM
Congratts Rich, you been excused and hope yr wife and Seb are doing well, good to have you back, what ever pace ...... ;D
#388 Footloose
Footloose
  • 15 posts
Posted 14 February 2014 - 09:16 PM
Wow nice work. Any more been done to this?
#389 hoody99
hoody99
  • 699 posts
Posted 14 February 2014 - 10:34 PM
Been watching this space ???? Still nothing ? Lol
#390 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,021 posts
Posted 04 May 2014 - 06:34 PM
It's a bank holiday so fingers crossed we might get an update :)
