Engine Identification
6 replies to this topic
#1 minituga
minituga
  • 220 posts
  • Local Club: Forumini
Posted 25 July 2010 - 06:15 PM
hi guys
bought a car that came with another very odd engine.
as usual the engine number plate is missing and the only numbers that i found are as follow:
head 12g295 with double springs
block 12a497 rwc 23758/30a
it should be a standard 998, but it came with some strange apendixes:
can anyone help?
#2 steveandhismini
steveandhismini
  • 80 posts
Posted 25 July 2010 - 06:31 PM
Im pretty sure that the 12g295 head is the head of choice for the small bore originally from the cooper 998, so thumbs up for that one. As for the block i think its a standard 998 block
thanks
Steve
Edited by steveandhismini, 25 July 2010 - 06:32 PM.
#3 IslandBlue
IslandBlue
  • 56 posts
  • Local Club: Mini Club Sussex
Posted 25 July 2010 - 09:15 PM
That is a 998 Cooper head casting and they look like D top (raised crown) 998 Cooper pistons.
Can't remember whether the 1000 tag means it's a Cooper block, not sure there's much difference in the basic block anyway, the pistons and cam are the difference in the short engine.
Manifold is a standard combined exhaust and inlet for the single carb.
Has a mechanical fuel pump whereas a Cooper would have had an electric pump under the rear subframe.
#4 minituga
minituga
  • 220 posts
Posted 25 July 2010 - 09:47 PM
those are some great news, as it came as a regular 998 engine :D
jackpot !!
#5 minituga
minituga
  • 220 posts
Posted 27 July 2010 - 07:38 PM
what about the gearbox?
it has no casting number, only the one on the last pic.
what does this mean?
#6 minituga
minituga
  • 220 posts
Posted 28 July 2010 - 10:31 PM
nobody?????????
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 29 July 2010 - 05:55 AM
998 cooper, the most important bits are there being the pistons and head, everything else is common with any other A series 998...
however the gearbox is wrong for a 998 cooper as it would of had a remote box.
Edited by Guess-Works.com, 29 July 2010 - 05:56 AM.
