Waxstat To Pre-waxstat
16 replies to this topic
#1 stormintrooper
stormintrooper
  • 2,072 posts
Posted 24 July 2010 - 04:12 PM
Basically what was better, the waxstat or the other kind of jet for the HS4, and if its the other kind, what would it take to fit one to a carb already fitted with a waxstat?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 24 July 2010 - 04:15 PM
Think general theory is that non stat are better for performance, waxstat economy.
All it takes to convert is two 1p coins :)
Here's one converted, remove the waxstat unit, replace with 2 coins
#3 stormintrooper
stormintrooper
  • 2,072 posts
Posted 24 July 2010 - 04:20 PM
wow :)
Well i do have economy in mind but right now would rather have a working jet that doesnt leak fuel! lol
http://cgi.ebay.co.u...sid=p2759.l1259
However i have seen this....now if you google the part number and replace capstat with waxstat it does return as being for a HS4
think its worth it?
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 24 July 2010 - 04:31 PM
looking at the cars that is for I'd say it was a HS6 jet ?? which will be to big.
Part number for the HS4 waxstat is lzx1111a
#5 stormintrooper
stormintrooper
  • 2,072 posts
Posted 24 July 2010 - 05:03 PM
d'oh
before i give it ago, i noticed the two jets look different, the waxstat has red ends to it..whats the crack with that?
Edited by stormintrooper, 24 July 2010 - 05:03 PM.
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 24 July 2010 - 05:08 PM
the red ends on the waxstat are just protective covers.
BUT
You can't just replace a waxstat jet with a non waxstat theres a conversion kit, the choke assy needs to be altered.
Thats why I converted using the 2 x 1p's :)
#7 stormintrooper
stormintrooper
  • 2,072 posts
Posted 24 July 2010 - 05:34 PM
so basically if i get the cheaper jet all i need are the two 1p's to convert it?
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 July 2010 - 02:58 AM
The "cheaper" jet is usually the "solid" jet. WaxStats cost more. The one on eBay may appear cheaper, but you need to make sure it's right for an HS4 as mentioned above. (I think HS6 carbs used jets with .100" through holes while HS4 carbs use jets with .090" through holes... but someone will have to confirm this.)
If you have an HS4 that uses a WaxStat jet, the coin conversion is easy to do. Alternatively, there are adapters that allow you to fit a solid jet to a WaxStat carb. If you have an HS4 that uses the solid jet, you need to stay with a solid jet.
#9 icklemini
icklemini
  • 2,982 posts
Posted 25 July 2010 - 08:44 AM
Part number you need is AUE1111,
This is a new conversion jet that replaces the waxstat jet.
Cost is about £20
HTH,
Dave
#10 stormintrooper
stormintrooper
  • 2,072 posts
Posted 25 July 2010 - 12:31 PM
Cost is about £20
HTH,
Dave
part number for where though? didnt work on minispares
#11 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 25 July 2010 - 12:39 PM
Here it is
http://www.sucarb.co...l.aspx?id=28089
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 25 July 2010 - 12:41 PM
and in all honesty im not even sure it it is a leak from around that area...im just assuming, and seing as it appears to only be leaking when its running its not like i can take it off to look at
#13 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 25 July 2010 - 02:52 PM
ive got one of the aue1111 jets if anyone wants one, i decided to stay with my waxstat
#14 stormintrooper
stormintrooper
  • 2,072 posts
Posted 25 July 2010 - 06:16 PM
how much chap?
#15 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 25 July 2010 - 09:45 PM
£10 + £1 for postage
