Gearbox Oil Leak, Hole In Casing
2 replies to this topic
#1 1984mini25
1984mini25
  • 8,784 posts
Posted 23 July 2010 - 02:11 PM
Basically the mini has been dropping a trail of oil behind it were ever it goes, popped out to buy some fresh oil and filter (could do with being changed) ready for it to be dropped if it turned out to be the diff or gear rod seal.
Only now after jacking the mini up, cleaning off the gearbox as best I could, not only is the gear rod seal leaking but I’ve also got this one.
Which appears to be a small pinhole in the casing, my question is how cheaply can I fix it?
#2 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 23 July 2010 - 02:16 PM
i imagine it could be fixed with one tiny blob of TIG welding, or brazing.
could get someone at a machining place to do it on their lunch break for a tenner probably?
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 23 July 2010 - 02:22 PM
or give it a real good clean, rough it up and chemical metal it.
