Best Way To Remove Paint For Respray?
18 replies to this topic
#1 m_brady15
m_brady15
  • 130 posts
Posted 23 July 2010 - 11:08 AM
Hello everyone,
Im about to start stripping back my mini shell for a complete respray.
I can't afford to get it acid dipped or anything like that, so im doing it myself.
Is the best way to remove the paint by using nitromoors? If so how much nitromoors will I need and where is the best place to get it?
I'm open to all other ways of removing the paint.
Is using sanding pads a bad idea?
Many thanks
Miles
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 23 July 2010 - 11:15 AM
Nitromors will cost a fortune, you need loads of the stuff.
I've only tried this on small areas such as bonnets and boots but paint thinners and something like 240 grit paper works well. You can get 5 litres of gun clean quality thinners for about £10
#3 Ethel
  • 25,919 posts
Posted 23 July 2010 - 11:31 AM
I'd just sand it, if the paint's well stuck on it'll be a better base than bare metal.
#4 Sam14
Sam14
    TMF Mug
  • 1,221 posts
Posted 23 July 2010 - 11:38 AM
Standard paint stripper from a local DIY store - not to sure it would work
Wire brush on a drill - be careful not to start going into the bodywork with it though
Grit/sandpaper - to build those muscles that you never new you had?
Or park it in a rough area and hope that some chavs throw paint stripper over it seeming as thats the latest craze with them?
* i am not suggesting all chavs are in that manner before you start whaling away
#5 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 23 July 2010 - 03:07 PM
I've taken mine back to bare metal. It took £10's worth of paint stripper to get most of the paint off on the underside of the bonnet and then I had to end up sanding it. I've used a 120 grit sanding disk in the angle grinder on a slowish speed.
#6 jack_marshall
jack_marshall
  • 2,540 posts
Posted 23 July 2010 - 05:40 PM
Paint stripper can be risky if theres any hidden remnants your fresh paint job could be spoilt.
If your bare metaling the shell then 80 grit on a DA is the best way. You'll still need to strip the fiddly bits by hand though.
If your current paintwork is good then you dont need to bare metal, only bare metal and sort the problem areas.
#7 joe90gt
joe90gt
  • 288 posts
Posted 23 July 2010 - 07:41 PM
I'm taking mine down to bare metal with those scotch brite dics on an angle grinder it aint cheap or clean but very effective and quick, paint stripper could contaminate and is a pain to clean off, cheap enough if you buy bulk from a specialist, finishing off with a DA and a delta sander, if the paint is OK just sand it ready for the new coat, you don't want to make work for yourself, dont forget to get your panel degreaser, tack rags etc etc as well
#8 Timify
Timify
  • 217 posts
Posted 23 July 2010 - 08:04 PM
Theres two options i use, thats either a flap wheel or a wire wheel. Both attach onto an angle grinder.
#9 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 July 2010 - 08:13 PM
A bare metal respray realy is a huge amount of work for very little reward. I've always just rubbed down the existing paint work thoroughly using a sanding block & a fine grit paper, then blown over a coat of high build primer before rubbing down again to fill any imperfections in the old paintwork. To some extent the extra paint thickness of the old paint beneath can also give some depth to the new colour too.... & whilst I have no doubt that a pro autorefinisher will disagree this.... If you choose to strip back to bare metal, at the end of the day the only person that will know that you went to all the effort of a bare metal respray will be you!!
#10 rossimini
rossimini
  • 23 posts
  • Local Club: WOT NO BRAKES
Posted 23 July 2010 - 08:14 PM
i would suggest sandpaper as you will have better base to paint over, but thats just my opinion
#11 clovus
clovus
  • 231 posts
Posted 23 July 2010 - 09:21 PM
I've always been worried about just sanding the existing paint and then the new spray job coming out poorly so have gone the bare metal route each time. Sure it takes longer, but everything seems to take longer on a mini, like there's some sort of bizarre mathematical equation at work - time taken is inversely proportional to the size of the car. Try a polycarbide sanding disk, will take off rust and paint pretty effectively. Wear a dust mask and ear plugs....
#12 frenchie851
frenchie851
  • 168 posts
Posted 23 July 2010 - 10:03 PM
well there is sand blasting but then you have to start worrying about warping your pannels so apparently a nwer thing is soda blasting. More gentle but realy does get rid of your paint!
#13 samsfern
samsfern
  • 5,243 posts
Posted 23 July 2010 - 10:17 PM
soda blasting is good :) just dont hold it in one place for a long time :)
#14 m_brady15
m_brady15
  • 130 posts
Posted 24 July 2010 - 12:43 PM
Thanks for the information guys :)
Miles
#15 zbc
zbc
  • 40 posts
Posted 27 July 2010 - 08:39 AM
I agree with this, I have taken my mini back to bare metal with the scotch brite wheels. Its a huge amount of work.
