1978 Clubman Restoration
#46
Posted 04 October 2010 - 06:50 PM
#47
Posted 14 October 2010 - 06:31 PM
hand brake is on cable attached and working just unsure on one or two things
will be painting few bits this weekend such as roll cage' twin tanks and grill should get roll cage and twin tanks fitted this weekend
will upload loads of photos tomorrow for sure
also got some more goods to day such as new newton commercial grey carpet' battery cable to front of car seam trims and clips
#48
Posted 16 October 2010 - 08:31 PM
here are my head lights bowls and bulk head blanking plate ready for primer going to paint matt black tomorrow
http://i833.photobuc...85/DSC00711.jpg
here are my cooper s twin tanks in place to see how they fit
http://i833.photobuc...85/DSC00713.jpg
i decided to matt black the lights as i am loving the matt black look with the imperial blue
http://i833.photobuc...85/DSC00714.jpg
side view of car
http://i833.photobuc...85/DSC00715.jpg
out side photo of engine bay
http://i833.photobuc...85/DSC00716.jpg
you can see from the photo the effort i put in flushing the turbo box in to the bulk head it took 8 hours filing and sanding it but was well worth the end result
http://i833.photobuc...85/DSC00717.jpg
http://i833.photobuc...85/DSC00718.jpg
side view of car
http://i833.photobuc...85/DSC00719.jpg
http://i833.photobuc...85/DSC00720.jpg
new parts from mini sport engine steady' gear box steady' bonnet internal pull' chrome mirrors' pedals' steering column bushes' etc etc
http://i833.photobuc...85/DSC00721.jpg
photo of car in side
http://i833.photobuc...85/DSC00722.jpg
twin cooper s tanks painted matt black looking good
http://i833.photobuc...85/DSC00723.jpg
http://i833.photobuc...85/DSC00724.jpg
rear part of roll cage painted matt black
http://i833.photobuc...85/DSC00725.jpg
http://i833.photobuc...85/DSC00726.jpg
tell me what you think so far guys and girls
#49
Posted 17 October 2010 - 05:32 PM
got to sort out some trim to sit over the arches in the back before i can put roll cage in or my carbon fiber door cards in
will take some photos off it tomorrow to upload hope to get the cage in this week get the boot finished off and most off the inside together
#50
Posted 17 October 2010 - 05:36 PM
#51
Posted 04 January 2011 - 09:25 PM
tanks are in and painted' boot on and built up rear roll caged holes drilled dashes glued in all rubbers on roof glued back in place
scratched the in side of the car and roll caged scratched trying to fit so need to paint it again tomorrow
will keep up dating better now will up load some photo soon
#52
Posted 16 January 2011 - 10:45 PM
here are some photos for now
speedo clocks
http://i833.photobuc...85/DSC00750.jpg
rear section of roll cage
http://i833.photobuc...85/DSC00751.jpg
http://i833.photobuc...85/DSC00753.jpg
heater box
http://i833.photobuc...85/DSC00758.jpg
made my own bracket to hold heater box in as moved it forward because of turbo box in bulk head
http://i833.photobuc...85/DSC00759.jpg
http://i833.photobuc...85/DSC00760.jpg
twin tanks in
http://i833.photobuc...85/DSC00761.jpg
made my own brackets to hold tanks in
http://i833.photobuc...85/DSC00762.jpg
http://i833.photobuc...85/DSC00763.jpg
http://i833.photobuc...85/DSC00764.jpg
just a few shots of the back
http://i833.photobuc...85/DSC00765.jpg
http://i833.photobuc...85/DSC00766.jpg
will upload again soon
#53
Posted 23 January 2011 - 09:47 PM
#54
Posted 01 February 2011 - 11:36 PM
engine bay at moment
http://i833.photobuc...85/DSC00767.jpg
brought a internal bonnet release kit what they dont say is catch is to small for s club man had to ******* about to take bits of new one and fit to old one
http://i833.photobuc...85/DSC00770.jpg
http://i833.photobuc...85/DSC00773.jpg
http://i833.photobuc...85/DSC00777.jpg
http://i833.photobuc...85/DSC00776.jpg
air vent under drivers side wing would not fit due to coil over so had to mod that as well
http://i833.photobuc...85/DSC00780.jpg
better up dates soon hopefully just brought for the engine
Head Gasket Set - Mini 1275cc - Turbo
Gearbox Gasket set
Mini Sport Clutch Pressure Plate - Lightened Steel,
Mini Sport Lightened Duplex Timing Gear & Chain Set
Ultralight Steel Flywheel - 4.423kg - pre engaged,
Clutch Flywheel Steel Drive Strap - pre Verto,
Clutch Flywheel Steel Drive Strap Bolt - pre Verto,
Flywheel Bolt Locktab - pre Verto,
Clutch Diaphragm Spring - Fast Road - Orange,
Clutch Plate - AP Fast Road
Clutch Slave Cylinder - Diaphragm clutch,
Clutch Release Bearing - Tall type,
Clutch Arm - pre Verto - Long,
Clutch Arm Return Spring - pre Verto,
Clutch Release Plunger - Pre Verto,
Clutch Hose - Goodridge Aeroquip,
Rod Change Gear Linkage -Rubber mounting
#55
Posted 16 February 2011 - 10:39 PM
brought a brake servo unit off ebay have stripped it to clean it and repaint it will up load photos tomorrow
heres some other photos of a few bits that i have done
dash
http://i833.photobuc...85/DSC00781.jpg
http://i833.photobuc...85/DSC00782.jpg
http://i833.photobuc...85/DSC00783.jpg
started fuel tank fuel lines
http://i833.photobuc...85/DSC00784.jpg
http://i833.photobuc...85/DSC00785.jpg
brake line
http://i833.photobuc...85/DSC00786.jpg
http://i833.photobuc...85/DSC00787.jpg
through car
http://i833.photobuc...85/DSC00788.jpg
http://i833.photobuc...85/DSC00789.jpg
engine bay
http://i833.photobuc...85/DSC00790.jpg
http://i833.photobuc...85/DSC00791.jpg
http://i833.photobuc...85/DSC00792.jpg
#56
Posted 15 May 2011 - 09:58 PM
My mate comes back of holiday in a weeks time so will build the engine up then got all my new parts will list them all when building begins
Heres what the mini looks like at the moment dash all in with gauges and glove box had auto electrician in monday did all wiring for fuel pump' stereo' 6x9' 3 gauges' 12v point' wire for alarm and extend the wiring for the starting motor because ive gone from inertia to pre engaged
test run of seats and harnesses all hook points bolt in place
roll cage finally in
and started to put newton comerical carpet in place
not to far of really cant wait
Edited by davetherave1985, 16 May 2011 - 07:04 PM.
#57
Posted 16 May 2011 - 10:29 AM
#58
Posted 16 May 2011 - 07:07 PM
