Shortie
254 replies to this topic
#31 minilester
minilester
  • 770 posts
Posted 12 September 2010 - 02:16 PM
??? how did you do that?
.. i want an internal boot release now :lol:
loving the bonnet, tasty bit of work :angry:
one more question... (sorry) could i get a link to where you got those archs please.... pleeeeeease..
#32 superman
superman
  • 736 posts
  • Local Club: Dorset Mini Club
Posted 12 September 2010 - 05:42 PM
Tricky question, did you mean the boot release? (hope so)
the main release is out of metro,you could use an internal mini release but turned out quite simple, removed handle welded hole, actually use an old wheel nut welded onto the boot and fitted the pin and spring from the bonnet, using a cut off of 25mmx25mm square tube i welded this under the top lip and attached a bracket holding the bonnet release from the metro, just a case of lining things up and mounting the release handle
thanks for your comments on the bonnet, cost a whopping £14
Wheel arches from minispeed (Wheel arches - classic works wide Part No: c-stn71 ask for the ones without the lip)
that was a bargin as well they didn't charge me for them, bonus
hope that helps just ask if you have anymore questions or want any close up piccys
Cheers Colin
Edited by superman, 12 September 2010 - 05:43 PM.
#33 superman
superman
  • 736 posts
Posted 19 September 2010 - 07:08 PM
progress update, been a bit busy with my mates mini's but still managed to get a bit done, welded all the seems around the headlights
(that will stop the seam rusting) also got the shortie out the front and start a bit of the rubbing down, boot nearly ready for primer
Attached File  Picture_063.jpg   308.79K   83 downloads
#34 tony13
tony13
  • 267 posts
Posted 19 September 2010 - 07:27 PM
liking the bonnet. looks really nice :) any more progress
#35 superman
superman
  • 736 posts
Posted 20 September 2010 - 06:39 PM
Thanks Tony13, glad you like it, i've not been able to get out and work on the car much but its getting there
The only things i've managed to get done (but not taken photos) finished off switches on dash board and smoothed off/filled all the holes under the bonnet for that smoooooth look
As things stand at the minute the only panel that we think has not been modded is n/s/f inner wing
#36 Mini-Mad-Craig
Posted 20 September 2010 - 06:43 PM
Sounds good matey! keep it coming!
#37 chippy2710
chippy2710
  • 38 posts
Posted 20 September 2010 - 08:26 PM
Really dig the bonnet. Does the KA interior just naturally slot in or does it take quite a lot of work?
#38 superman
superman
  • 736 posts
Posted 21 September 2010 - 08:05 PM
Hi Chippy2710 thanks for your comments, the dashboard took over 40hrs work of cutting, plastic welding and poprivets, i even cut around the curved section which houses the dials and switches then sunk that back into the rest of the dash to give more clearance for the gear lever as i thought it was a bit close, after all that work i took it out and lobbed it the back of the shed
Hey you never know unless you try these things
Colin
#39 chippy2710
chippy2710
  • 38 posts
Posted 22 September 2010 - 09:13 PM
You are actually mental aren't you?
#40 superman
superman
  • 736 posts
Posted 26 September 2010 - 05:35 PM
some say he is mental..........all we know is..........the dash didn't look right
#41 memad1275gt
memad1275gt
  • 15 posts
Posted 26 September 2010 - 07:06 PM
and some say he might be............ ben collins:)
#42 superman
superman
  • 736 posts
Posted 05 October 2010 - 04:45 PM
could be.....
#43 Goatboy
Goatboy
  • 252 posts
Posted 06 October 2010 - 06:44 AM
Love it! Makes me want to attack mine with an angle-grinder :shifty:
#44 superman
superman
  • 736 posts
Posted 10 October 2010 - 02:59 PM
thanks goatboy,always glad to hear from people that like what im doing.... cheers mate
#45 superman
superman
  • 736 posts
Posted 26 October 2010 - 04:11 PM
Not much to update really, spent a load at castle coombe, all parts still in bag
all the time i've spent working on the shortie has been rubbing down not much point of pictures
Oh the new compressor turned up today brand spanking new and broken
i'll post some photos when i've got something new to show
colin
Edited by superman, 26 October 2010 - 04:12 PM.
