It is a compete guide to building a single seater off road buggy with a small motorbike engine
I got to reading it again, and decided that i'd quite like to give it a go, so i ordered 18m of box section steel and it arrived yesterday
Went to B&Q to get some sheet chipboard to make a building frame template, and today i got the plan of the buggy drawn onto the baseboard, and cut the first 2 bits of box section, which are held in place with the little wooden blocks, so effectively it is a jig.
Tomorrow i will be cutting all the cross members and front kick up section and tack weld it together.
Baseboard with template drawn:
3 lengths of 6.1m 30mm x 30mm x 2.5mm box section
2 chassis rails cut and jigged:
The front of the chassis rails have a slight mitre to give a 15 degree kickup for the front section of the chassis:
Stay tuned..
