Accelerator Pedal Sticking
5 replies to this topic
#1 998 Chris K
998 Chris K
  • 14 posts
Posted 16 July 2010 - 11:11 PM
Hey, I have an '86 Rover mini, 998 but with an HIF 44 carb and when I let off the accelerator, it gets stuck down a bit. When pressing it with the engine off, I can here the metal throttle cable scraping the sides of the hole it goes through in the firewall, and I have no idea why its doing this, cause it can't be normal.
Any answers or advice? it would help out so much.
Thanks!
Chris
#2 Ethel
  • 25,922 posts
Posted 16 July 2010 - 11:21 PM
Have an investigate. The cable slots in to the top of the pedal with a spring clip over the top to keep it in place, you could hold the throttle open with a spanner to create enough slack in the cable.
Sometimes a poor engine earth results in earth making its way back to the battery via the carb cables which can weld them to the sleeve.
#3 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 16 July 2010 - 11:57 PM
Get a second body in there to operate the pedal while you have a nosey around the bulkhead
#4 998 Chris K
998 Chris K
  • 14 posts
Posted 17 July 2010 - 08:07 PM
yeah me and my dad tried a little trick which involved putting a straw around the cable and then put the straw into the little tunnel that the cable goes through, and also gave it a lick of grease on it. It worked absolutely fine for half the day, then on the way back home it went back to getting stuck on a little so the engine would rev up each time before shifting=[ it was kind of embarassing with all the other cars around. haha
#5 mini-geek
mini-geek
  • 1,169 posts
Posted 17 July 2010 - 08:09 PM
Just buy a new cable. They are dirt cheep..
#6 998 Chris K
998 Chris K
  • 14 posts
Posted 17 July 2010 - 09:34 PM
Oh how I wish that would work. The thing is, it IS a brand new cable. Maybe a month old AND I just got it registered and on the road, so it hasn't had much wear and tear at all.
