Well it's been a while. The car was having a tonne of problems starting and running in November and with other things on my mind and insurance on another car it got left to go green on the road. In late November I moved out of the parents house into my own with my partner and were lucky enough to get one with a driveway, so I managed to work through the dark to get it running one last time just before the MOT and insurance ran out to stick it on the new driveway. Again, I've left it alone since then and have had my time taken up with a new family and a family car to get running well.
The partner and I are both car nuts and met at a Mini show, and with both fun cars off the road we've been really missing them. However I was thinking maybe it was time to let someone else play with the Viva and to get something more suited to me at this time. With my age increasing, insurance slowly coming down and a 2.0 turbo for a daily drive, the bumpy, slow Viva wasn't interesting me too much. After much searching I was stuck with a decision between keeping the Viva, but actually getting round to doing the tidying up it needs, or tidying it up suitably, selling it and with the proceeds buying an E30 318is/325i or my number 1 choice, a mk3 Supra. Good looks, 80's J coupe, 3.0 engine...now I was interested. But I just can't decide if I want to get rid of the Viva.
Anyway, whatever I choose, the Viva will need a bit of work, so I figure if it goes well and I still enjoy working on it, I'll probably keep it, finish the engine build and start collecting parts for a 160VVC K-Series conversion. If I don't enjoy it it'll be replaced by a Supra.
As a tiny little side project so that I could start immediately, I decided enough was enough and the crappy Stromberg carb was going to go for good. In it's place I've been modifying an old HS4 I had lying around from my Mini days to be used on the Viva manifold.
Today I finished off rebuilding the carb with parts meant for an 80's 1275 Mini and finally stuck the set up on the car with a new fuel pump I also conveniently found lying around the garage and a slightly larger Chevette fuel line to match the pump and carb. Unfortunately I couldn't try to start it as the Viva battery is completely flat and the Mini battery I pinched isn't quite charged enough, so that's a job for tomorrow. It also needs a new slightly longer throttle cable and a new/modified choke cable, and needs the vac and breather pipes sorting. I'll probably also modify the standard Viva air box to work with it if it will still fit as I figure a cone filter isn't a great idea directly over an exhaust manifold.
Things I want to do in the coming months:
Finally learn to weld - I now have my partners welder down with us so this can begin following Tony's guide.
Clean up the engine bay and move the battery tray out to fit a bigger battery
Take up the seats and carpet, treat the floor for any rust (only a little bit of surface rust) and repaint.
Tidy up the wiring running down the car and behind the dash and wire in the reverse switch
Repair the rear arch seat belt mounting points and a little patch in one rear arch
Sand down and repaint the rusty patches around the car, mainly the valences with a little around the arches and wings, but it's all surface so no bodywork needed, just need to find a good paint match.
New carpet and if I keep it a cars worth of sound proofing.
Front suspension still needs some sorting as it's running on bump stops.
Might try to do something with the exhaust but god knows what.
Finish swapping steering wheels about and get the DTV wheel refurbished.
And as of today I need to sort a second hand Tex mirror as my N/S one snapped off
I can buy new but they're £50 each and it'll look silly with one new and one weathered.
Alternatively I can get bullet/torpedo mirrors for £20 each, but I'm not sure they'd look right. Opinions please?
