Whistling Noise From Engine
Posted 14 July 2010 - 04:26 PM
I have noticed in the last week or so my engine (1275 metro ) has started making a slight continuous whistling noise coming from the radator side, fitted a new water pump about a month ago so i hope it isn't that. Any ideas and should i be worried its running fine.
thanks
Posted 14 July 2010 - 05:36 PM
Posted 15 July 2010 - 02:02 AM
Could also be something catching the altanator fins. Put the oil rag near it other day fired her up n had high pitch hissing sound, suprised it didnt eat it for breakfast.
Posted 15 July 2010 - 07:55 PM
Posted 15 July 2010 - 08:03 PM
Is your fan belt adjusted ok?
Yea its def not the fan belt, just a very light whistle noise
Posted 15 July 2010 - 08:05 PM
they make whistling noises
so do turbo's
belts can also try spraying wd40 on the belt why the engines running
and see if it stops then if it dose its the belt its asorbed water
Posted 15 July 2010 - 08:14 PM
air leak?
so do turbo's
You shouldent realy put WD40 on rubber it is bad for it, also would this not just cause it to slip and squeel like a pigy.
Just wondring as ive never try'ed it
However i would say air leak from manifold or some where. But cheak everything maby fan fouling slightly
Bearings some times sound like that when there wearing out.
Edited by me madjoe 90, 15 July 2010 - 08:16 PM.
Posted 15 July 2010 - 08:28 PM
Posted 15 July 2010 - 08:52 PM
air leak?
so do turbo's
ive never ever heard of that
since when rubber on the belt absobs water it makes it squeel like a pig cause its getting hot as it spins
Duck oil & wd40 remove the water and stop the squeel and wont make the belts slip
i did it with mine and its not sliped or anything
Posted 15 July 2010 - 09:35 PM
Fair enought but oil generaly perishes lots of rubbers, I supose a few times can hurt.
But intresting to know i would have thought it would slip with oil on it.
Posted 15 July 2010 - 10:06 PM
The only other thing i can think off is that the noise started just when the rains came after a long (rare) dry spell.
i remember my friends mayfair doing that, squeaking after a bout of rain. doesnt do it anymore.
ill ask him tomoz what the problem was in the end.
Posted 15 July 2010 - 10:11 PM
WD40
http://en.wikipedia.org/wiki/WD-40
its safe but its better to replace the belt
i keep a can of wd40 in the mini for the pionts (y)
Posted 15 July 2010 - 10:56 PM
That would be great if you could, cheers.
Posted 15 July 2010 - 11:51 PM
