Best Paint Stripper?
32 replies to this topic
#1 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 July 2010 - 06:40 PM
Yes im after paint stripper for removing paint from my mini
don't say get it shot blasted or sand it back
i want paint stripper please
so anyone know any good ones?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 July 2010 - 06:50 PM
only used nitromours before.
And only used it on small parts rather then panels etc.
Its messy and hard work as the paint needs scrubbing off after the stripper as started to lift it.
Jordie
#3 mattsbmw
mattsbmw
  • 192 posts
Posted 10 July 2010 - 06:51 PM
Nitromors is the one most commonly recommended, just becarful with it though.
#4 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 10 July 2010 - 07:06 PM
Most paint stripper is good and does what it says in the tin, I like starchem stuff, tends to be more gloopy and stays on the panel longer. Just be very careful and wear goggles and thick rubber gloves! you might think it's overkill with the goggles, but if you get any in your eye, you'll know why.
#5 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 July 2010 - 07:11 PM
yeah i used industical machine paint stripper on my bike and it ate the clothe but took it back to metal and killed off the rust
but the stuff i had was only a small bottle and its not made anymore
just wondered what else is kicking about
dose it remove surface rust okay?
#6 mk3cortina
mk3cortina
  • 677 posts
Posted 10 July 2010 - 07:18 PM
well im halfway through is of paint stripping the WHOLE of my mini (previous owner enamel brish painted it so i can spray over enamel) anyway ive got two 1 liter tins of paint stripper tham in working with, one is a wilkinsons own brand, and the other is notromorse. as far as i can tell they work the same, it lifts the enamel paint off straight away, but the original car paint gets softened up and i need to go over the whole panel with either a sander or a wire wheel on the grinder. its hard messy work but i just do a panel at a time.
#7 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 10 July 2010 - 07:20 PM
Paint remover doesn't do anything to rust, it just removes.. paint.
#8 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 July 2010 - 07:36 PM
ah well and least it get rid of the paint so i can then get rid of rust ;)
British herraige panels? better fitting right?
#9 mk3cortina
mk3cortina
  • 677 posts
Posted 10 July 2010 - 07:38 PM
heritage panels fit better yeah
#10 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 July 2010 - 07:39 PM
good good (y)
im not body expert ):
but im learning ;)
#11 pablo_agogo
pablo_agogo
  • 20 posts
Posted 13 July 2010 - 08:37 PM
Friend of mine has used this before and found it less messy than highstreet strippers [insert pun of choice]
#12 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 18 April 2016 - 06:01 AM
Nitromors
Been looking at this stuff, anyone think its worth a go?
#13 Daz1968
Daz1968
  • 2,058 posts
Posted 18 April 2016 - 09:03 AM
I have been using a hot air paint stripper gun and scraper on mine and works pretty well, not to much mess either. It is slow but doing an hour at a time as no rush.
#14 bluedragon
bluedragon
  • 286 posts
Posted 18 April 2016 - 09:11 AM
Wow, that must have been a low-grade paint used. Not hurling insults mind you. A factory paint job (especially for a classic Mini vintage vehicle) would have been baked at 2-300°C from the factory, so if a heat gun is peeling it off, it must have been a low-durability paint like cellulose. (or perhaps the heat gun is more like a blowtorch?)
#15 jeebz
jeebz
  • 155 posts
Posted 18 April 2016 - 09:51 AM
Nitromors
It's pretty good stuff, I've used it on bonnets and bikes before.
What are you using it for, what kind of paint are you trying to take off?
