fully mappable distributorless ignition systems
9 replies to this topic
#1 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 23 November 2005 - 08:57 PM
where can i find one in the uk? ive found many in the good ol US of A but none in the UK...
also, as a general query, what happens to where the dizzy normally sits? is it blanked off?
as im assuming a crank sensor is used instead of dizzy running off the camshaft?
cheers
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 November 2005 - 10:14 PM
Lynx racing do one called PoleStar, also supplied by Slark... Lynx clicky
Slark Clicky
MiniMinus has one on his, and I've been toying with the idea myself... fully mappable and can be programmed by a laptop !
#3 Madmax
Madmax
  • 2,638 posts
Posted 23 November 2005 - 10:42 PM
bingo, spot on there GW, many thanks
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 November 2005 - 11:09 PM
Or Weber make one called Alpha (it's also availalbe as a full fuel injection system) which is supplied by Webcon.
Or Luminition make one (which again is also available as a full fuel injection system)
Or you can build your own.
There's a few options.
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 24 November 2005 - 12:22 AM
Type in any search engine the either of the following, Megajolt, Megasquirt, Megasquirt 'n' spark :cheese:
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 November 2005 - 08:15 AM
Arnt the magesquirt stuff which is all based around an injection system.. ?
#7 Jammy
Jammy
  • 25,397 posts
Posted 24 November 2005 - 08:52 AM
MegaSquirt
Very handy Forum
#8 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 24 November 2005 - 09:08 AM
megasquirt does ingnition and injection i believe, but you can use it for ignition only.
I'll be using megajolt in the near future when i get round to ordering the ECU and going scrappy ratting for the EDIS bits :(
#9 kada1980
kada1980
  • 608 posts
Posted 24 November 2005 - 09:55 AM
Yep megajolt is for ignition, can be 2d or 3d. Adding sensors like TPS and MAP.
And megaquirt is for fuel but it can be easily modded to run ignition via a ford edis module via the FIDLE output.
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 24 November 2005 - 06:26 PM
yep, I run Megasquirt for ignition only. And at less than £100 fully installed it's cheap as chips.
