How Do I Wire An Oil Temperature Sensor?
Posted 07 July 2010 - 04:48 PM
Does anyone have any ideas where the sensor would go. Its got a universal 1/8 NPT thread so should fit strsight into the block if i could only find the place to put it.
The oil pressure sensor has taken the place where the old oil warning gauge was, and the only other place i can find is for the water temp sensor, so i obviously cant put it there.
PLEASE HELP ME!!
Posted 07 July 2010 - 05:12 PM
http://cgi.ebay.co.u...=item3f013707c1
Whilst searching for that I did find this though
http://cgi.ebay.co.u...=item563d635db5
You'd have to check clearance though
Beaten to it again.....But yes as above..
Edited by AndyMiniMad., 07 July 2010 - 05:13 PM.
Posted 07 July 2010 - 05:19 PM
Never fitted a temp sensor, but it occurred you could use the adaptor normally used for plumbing the warning light and pressure gauge into the block.
Thats absolutely brilliant. That second link is spot on what i need. I tried a couple of motorfactors near me and they had no idea what to do, even though i suggested trying a T-Piece connector for both the oil pressure and temp - and they're supposed to know what they're talking about. I do love the forum, literally the best thing since sliced bread.
One of them mentioned he though there might be a spot on the sump pan where i could hook it up. I havent had a look though. Could he be right or was he just making it up to appear to know what he was on about??
Posted 07 July 2010 - 05:25 PM
Can't say I've noticed any other connections on the sump.
Posted 07 July 2010 - 05:28 PM
You may be able to find/make an adaptor that will screw into the sump plug hole though you will then loose the magnet...
The sensor extendes quite some way after the threaded section and the one i tried on the standard sort of mini t-piece (second link) would not fit becasue of this.
Posted 07 July 2010 - 06:16 PM
by the way, Tomf, where are you based as a garrage? Im from Bromley and have tried a few supposed specialists but they have all had their problems and im looking for someone else to entrust my mini with if its close enough.
Posted 07 July 2010 - 06:19 PM
Posted 07 July 2010 - 09:40 PM
Advantage is you can take the plate off the back of the gearbox and do all the mods on the bench, and if you don't like it, just put a standard plate back on to the gearbox.
Posted 19 January 2016 - 02:37 PM
goodmorning
i'm still trying to understand how to fit smiths oil temperature....where should i screw oil capillary ? i have a british open 1996 spi
thanks...
Posted 20 January 2016 - 12:27 PM
Posted 20 January 2016 - 12:38 PM
Posted 20 January 2016 - 01:38 PM
Thanks for posting that link UKCooper. I was going to post a link to that type of adapter. If you fit an oil temperature gauge (mechanical or electric), the sensor needs to be in the flowing oil. That's why the filter head adapter is a good solution. Other suggestions such as T fittings off the oil pressure line do not put the sensor in the flowing oil and they also put the sensor out far from the block. The result is a much lower temperature reading with quite a bit of error. That totally negates any benefit of having the gauge.
It is your car and to each his own regarding gauges and customization. Regardless, I offer the following comments on oil temperature gauges.
If you race, an oil temperature gauge is a must-have item. On a street car they will tell you little and are largely eye candy. The oil temperature will come up slowly and typically stay in one place most of the time. Some say "Hey, it will tell you the engine is overheating if you lose all your anti-freeze". That is true but there are usually other signs (like steam) that tell you the car is overheating long before the oil temperature will. Again, it's your car and you should enjoy and customize it the way you want. Just don't expect to learn a lot from an oil temperature gauge on a street car.
