However, iv`e bought another mini, This is a standard 998, and will be staying that way. Its my daily driver, but i dont mind pottering about in it. Performance isen`t what i`m after with this car.
Slow and well, errr slow is the aim of the Game. So adding a good 100kg with a decent stereo doesn't make much difference to me.
Now shall i babble the kit shall i?
Sound insulation
Firstly. Sound insulation. Ive currently have 30 square foot or 2.5mm thick E-DEAD in my car. However this will probably Increase to 60 As iv`e only managed to get both sides of the parcel shelf, the bootlid, boot, rear bulkhead and fuel tank done so far and probably used 3/4 of the roll.
Now sound blocking, is going to be a budget solution. (Why go expensive when you don`t need too?) Camping mats.....(No really) Chop these up and they act as a cracking noise barrier! Cheap solution. Around 5 pounds each, I recon i`m going to need 5 in total.
25 pounds for that then. The roll of e-dead was 42 pounds. That brings sound deadning upto around the 120 pounds mark. If i use a second roll of e-dead.
Front end
Firstly, I`m straying away from the normal Mini setup. My component front end will consist of three speakers a side.
Also to add to this, Its going to be run fully active. For this!
So for the front speakers.
Rainbow SLX230 DELUXE
This is my high and mid range (On their way!)
I`m still searching for 8 inch mid bass speakers.
Amplification
I`m going to be running two amplifiers.
A single amplifier for the front end.
A single for the sub woofer.
I already in my possession. Have an amplifier for the front end! Old School goodness!
A Dragster DA606! Now you say, an un branded amp, not to worry. Its got a Denon board inside, top quality stuff this!
The single amplifier for the sub woofer i`m yet to source. However ive got my eyes on an old school Audio System amplifier.
Power
For this i have three distribution blocks.
An Auto leads 0 gauge in, 4 gauge out. Fused distribution block. 2 x 30amp fuse
An Auto Leads earth distribution block
Custom remote distribution block. (Me molesting some 19mm ally square bar for 10 minutes. 7x5mm holes. 3 tapped to m6)
Inline fuse holder 60amp fuse.
096 battery 75AH (Hope this will fit with a boot lining kit)
70 Amp SPI Alternator.
Cut off switch inline before 60amp fuse.
Knukonceptz wiring throughout.
Back End
As yet i`m unsure as to what sum i`m going to use and what box design.
Edited by Sam Walters, 06 July 2010 - 10:04 PM.
