Electric Fan Kits
26 replies to this topic
#16 chappy
chappy
  • 1,253 posts
Posted 06 July 2010 - 08:09 AM
Imagine if the control cct for the lecky fan failed or indeed the fan itself, No cooling at all!!!
Sooo... . Just like if the fan belt snapped?
yes it might fail, but then, so might alot of other things... thats the chance you take with owning a car.
anyway, motorbike fan... small, light and moves alot of air.. its the future..
Edited by chappy, 06 July 2010 - 08:11 AM.
#17 chappy
chappy
  • 1,253 posts
Posted 06 July 2010 - 08:10 AM
double post
Edited by chappy, 06 July 2010 - 08:10 AM.
#18 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 06 July 2010 - 01:35 PM
Yep just like if the fan belt snapped....But the point I was trying to make is that if you remove the mechanical fan in favor of an electric one you are then relying on thermostatic control and/or a manual overide switch. And a dc motor. More things to go wrong. I fitted the lecky fan, and used a relay to switch it on automaticaly when things get a bit warm, but i also have a switch in the car in case the relay fails. Also the electric fan is quite noisy so I would not want it on as my only form of cooling. But hey, its only my opinion. By the way I recon a mini corners better than a motorbike. 4 wheels on the ground instead of two. Mini ownership........ its the past.......the present.......and the future....
#19 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 06 July 2010 - 01:39 PM
lmao i dont think he meant he was a motorbike fan, ie a fan of motorcycles,
more like motorbike fans are very good at cooling and appear to be the future.
#20 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 06 July 2010 - 01:54 PM
Ohhhh I seeee.... Sorry not very good with cryptic answers. Thanks for enlightening me.
#21 maggies_minder
maggies_minder
  • 4,393 posts
Posted 06 July 2010 - 01:56 PM
lol its ok it just made me laugh,
now everyones singing from the same hymn sheet.
#22 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 06 July 2010 - 08:44 PM
Am I right in thinking you want rid of the mechanical fan in favour of a lecky one? I only say this as you say you want to eliminate the fan runing constantly. This I think would be a bad idea!! Imagine if the control cct for the lecky fan failed or indeed the fan itself, No cooling at all!!! I think your best option is to keep the mechanical fan and add a lecky fan under the front wing, controled either thermostaticaly or via a switch in the car.
Andy
Yeah I want to do away with the mechanical fan completely and just solely run and electric one. The mechanical fan does nothing when the car is moving above 30mph, the car is cooled by the air running through the grill, so I don't see any need to keep this fan when its doing nothing both once the car is moving, and when its stationary.
#23 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 06 July 2010 - 09:07 PM
Ok up to you really!! Consider an extra cooling device in that case. Heater matrix behind the grill maybe?? My lecky fan is really quite noisy and im not sure i would want it on continuously in town trafic. But thats just me.
#24 Southy
Southy
  • 1,579 posts
Posted 06 July 2010 - 09:32 PM
Which lecy fan are you running?The noise doesn't really bother me to be honest, car's running a weber and S/C box so I'm kinda used to it :D
Edited by Southy, 06 July 2010 - 09:33 PM.
#25 Southy
Southy
  • 1,579 posts
Posted 06 July 2010 - 09:35 PM
Just to add aswell after reading the other thread about by-pass hoses, the stat is drilled out with 6 evenely spaced out holes at around 5mm
#26 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 06 July 2010 - 09:39 PM
Its the one that came off the MG metro doner. Are they more noisy than others?
#27 Southy
Southy
  • 1,579 posts
Posted 06 July 2010 - 09:41 PM
More than likely yes, most of the modern day fan's are pretty much near silent running.
