It's taken an awful lot of time, mostly because of bad weather over the winter months and also because fitting out the mini has involved nearly a complete overhaul:
Interior
- renovation of the walnut dash
- fabrication of walnut switch panel to replace stock switch panel
- fabrication of a walnut bezel for the touchscreen
- fabrication of a boot kit
- fabrication of a center console (made so foot room isn't compromised!)
- replaced rocker switch panel with custom illuminated savage switches (lots of wiring!)
- lots of rewiring behind the dash because of lots of crap jobs done in the past!!
- hole cut in dash for touchscreen bezel
- radio relocated (from dash) lower down to center console.
- reupholstered seats in full leather (cream with racing green piping)
- new matching door cards
- new door locks (old ones were well worn)
- new carpets
- new heated front windscreen (de-ices in 30-40 secs!)
Exterior:
- new brightwork, ss grille and window trim
- new mini sport front vented/grooved disc brakes and alloy calipers
- new superfin rear drums
- full respray 1-2 years ago
To Do:
- finish off wiring new switches (hazards, 2 accessory switches)
- finish off LED strip footwell lighting
- fit HID xenon light kit
- new 12x6" deep dish wheels with stage 4 (?) arches
- fit walnut door cappings
None of this could have been completed without the knowledge and expertise of my old man - he's the guy who's done all the wood fabrication and switch wiring. It's one thing making these things, but it's an entirely different problem retro fitting them to such an awkward car - fitting the dash required custom made brackets, it all has to be installed in a specific order otherwise you physically can't get to the screws to tighten them all up! Another example, the centre console needs the front seats removed and the handbrake taken off, just to get the thing in and and out!!!
However, the upshot of all this custom fabrication means eveything is solid as a rock, doesn't creak - quite a feat in a car that's a bone shaker!
Without further ado, here's the install pictures. Sorry I didn't take pictures of the mini before I started (got a bit too excited) Will find some stock mini pictures off the web.
My pride and joy......
Edited by cheekynige, 02 July 2010 - 09:24 PM.
