Cam Timing..setup..could Be 180 Out
Posted 01 July 2010 - 11:22 PM
any one know anyone in the winchester area..that could help out ...just i dont want to move it ..either for money or parts.....
Posted 02 July 2010 - 09:08 AM
just move all the leads round 2 places.
Although I don't think you can actually put the cam in wrong if you just do it by lining up the dots on the cam gear and crank gear ??
Was the dizzy drive shaft removed, maybe thats in 180 wrong
Edited by lrostoke, 02 July 2010 - 09:10 AM.
Posted 02 July 2010 - 09:17 AM
I've had one for years and I suspect when I next strip the engine, it'll find it's way back on without me even looking at it..
Posted 02 July 2010 - 10:03 AM
Posted 02 July 2010 - 10:24 AM
Can be done in car, take rad out and off you go.
Am I right in thinking No4 should be firing when the dots are lined up?
Think your right there, that confused the hell out of me when I last fitted a chain and sprocket set
You'd expect everything to work of TDC No1, but its actually No 4 @ TDC (compression) when the dots on the gears line up.
Edited by lrostoke, 02 July 2010 - 10:37 AM.
Posted 02 July 2010 - 10:38 AM
Posted 02 July 2010 - 10:44 AM
Just looked for the photo, when you said 11 link chain.... GrahamC gave you the answer, it's a KENT HVC, and to be honest.... knocks spots off a belt drive you should have kept it on there... they are bullet proof...
Sadly it was very slack 40mm movement... I was looking at putting a tensioner on but it looked like a lot of slack to make up..
Posted 02 July 2010 - 11:27 AM
This is correct, to time a cam properly you need no1 to be at tdc but on the exhaust stroke otherwise you would not be able to measure the LCA of the inlet cam lobe, which will be opening... The LCA ( Lobe Centre Angle ) is the number of degrees after TDC that the inlet on No1 is open at it's maximum, obviously on the compression stroke and after the inlet is closed... This is where the quoted figures like 106 degrees (normal LCA for Kent cams) comes in. So for example, if you are checking a 'dot to dot' set up, using a DTI and a timing disk you can actually see how accurately the timing gears and cam are machined, and can adjust ( if not a vernier setup ) with offset woodruff keys... I've known 'dot to dots' to be over a tooth out in timing...
However, when you think about it, it's not the position of the crank which determines the 'stroke' it's on, it's the cam, so with pistons 1 and 4 @ tdc, you then turn the cam so that no1's inlet and exhaust are "on the rock", and then fit the timing gear.
Edited by Guess-Works.com, 02 July 2010 - 11:34 AM.
Posted 02 July 2010 - 09:48 PM
engine was kicking out over 105 bhp before
so i dont just trust any old harry on it..
michael
