Custom Induction Kit
45 replies to this topic
#31 minimad01
minimad01
  • 563 posts
Posted 07 July 2010 - 07:03 PM
any cold air makes a difference to an engine an the chap whos car the is in that picture said he didnt have enough people wanting to have 1 of them plenums to produce them as he offered to make them before
#32 l_jonez
l_jonez
  • 1,453 posts
Posted 07 July 2010 - 11:14 PM
a few years ago there was a chap over on minifinity who did some research regarding under bonnet temps. he set up temp sensors in different places and he found that after a relatively low speed (20-25mph) the air at the back of the engine next to the carb was the same as at the grill, which makes these induction type kits pretty pointles
#33 mattwho?
mattwho?
  • 844 posts
Posted 09 July 2010 - 02:51 PM
stop pishing on the dream lol
#34 Tupers
Tupers
  • 4,143 posts
Posted 10 July 2010 - 06:32 PM
Yeh and if everyone drove around at 20-25MPH then an induction kit would pointless but they don't do they. ;)
#35 jkjaxor
jkjaxor
  • 331 posts
Posted 10 July 2010 - 07:55 PM
he means anything above 20- 25 makes it pointless.
#36 Tupers
Tupers
  • 4,143 posts
Posted 10 July 2010 - 11:13 PM
I would have though that you'd still get the advantage of it essentially being a ram air system that in itself cools the air. l_jonez have you got a link to the thread about this on minifinity I'd love to do some more reading about this.
#37 l_jonez
l_jonez
  • 1,453 posts
Posted 11 July 2010 - 12:26 AM
yes i mean any thing over that speed makes it pointless. there is no such thing as "ram air" as the engine will only suck in a specified amount of air, to get any more into an engine you need forced induction.
had a quick search and i think this was one of the threads
http://www.minifinit...ay temp#p290685
and there is this
http://www.minifinit...ay temp#p501200
#38 carts60
carts60
  • 1,007 posts
Posted 11 July 2010 - 08:38 PM
There was also an article in one of the mini mags about 4 or 5 months ago where one of the racing mini companies took a mini to an air tunnel to test its aerodynamics with modified bits and bobs. Im fairly sure they found that the back of the engine bay is like a wall which stops all the cold air which gets caught by the grille, meaning the back of the engine bay is almost as cool as where the grille is. They also noted that when people prop up the back of the bonnet (to provide an outlet for hot air out of the back of the engine bay) they're actually causing a pressure difference between where the bonnet is raised and the engine bay which actually sucks in air and causes massive drag. - not that thats massively relevant to the current discussion.
#39 carts60
carts60
  • 1,007 posts
Posted 11 July 2010 - 08:39 PM
*sorry double post*
Edited by carts60, 11 July 2010 - 08:44 PM.
#40 andymini12
andymini12
  • 812 posts
Posted 12 July 2010 - 09:17 PM
http://cgi.ebay.co.u...=item4aa0b79933
lol what do people think of this for forced induction, do you reken it would do much ?
Andy
#41 l_jonez
l_jonez
  • 1,453 posts
Posted 12 July 2010 - 09:20 PM
yeah it will add weight and slow you down
#42 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 20 July 2010 - 09:38 AM
Just be careful in the winter, i had a similar set up on my old engine, then when it was really cold, the carb then freezes up!
#43 skaterava
skaterava
  • 1,857 posts
Posted 20 July 2010 - 11:43 PM
I read somewhere that induction kits make little to no difference on small bore engines anyway, Minis or not.
Edited by skaterava, 20 July 2010 - 11:43 PM.
#44 crossy71
crossy71
  • 55 posts
Posted 21 July 2010 - 10:16 AM
If you are trying to get cooler air to the carb then why dont you either use some thermal wrap on then LCB or if you can remove the manifold for a time get it coated in that new heat shielding ceramic coat which will reduce the heat produced by the exaughst in the engine bay and keep the heat in the exaughst which is supposed to help the exaughst systems efficiency so ive heard.
Doing it this way also means you dont have to have a big pipe cluttering up your engine bay, something like this was advertised in mini mag a month or 2 ago dunno if its the same company..... Zircotec
#45 mattwho?
mattwho?
  • 844 posts
Posted 25 July 2010 - 08:56 PM
http://www.nartube.n...H-rsZeLawI.html
looks good to me
Edited by mattwho?, 25 July 2010 - 08:57 PM.
