Custom Induction Kit
45 replies to this topic
#16 mattwho?
mattwho?
  • 844 posts
Posted 06 July 2010 - 01:46 PM
can you not take the old box off and make something to bolt on to the carb?? i just see a big surface area of the old box getting hotter then if you just have a pipe to the carb like newer card have right to the TB
like this i would say is better
been thinking of doing this for ages
Edited by mattwho?, 06 July 2010 - 01:46 PM.
#17 minimad01
minimad01
  • 563 posts
Posted 06 July 2010 - 03:35 PM
ye it probly would but i just dont have the fabrication skills to make a plenum is the sort of this you want
#18 skaterava
skaterava
  • 1,857 posts
Posted 06 July 2010 - 06:42 PM
I was considering this a while back. If i remove the standard airbox and filter, and instead fabricate something that bolts directly to the carb's air inlet, like mattwho has suggested, will this increase responsiveness in a 998?
I read something a while back suggesting induction kits only benefitted larger bore and more powerful engines, putting an induction kit on a small bore was negligible.
#19 mattwho?
mattwho?
  • 844 posts
Posted 06 July 2010 - 08:52 PM
well i run a 1275 but any cold air is good air
#20 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 06 July 2010 - 09:01 PM
it shouldnt be to difficult to knock something up that will fit onto the standard air box elbow, even a modified elbow that you can bolt upsidedown to the exsisting elbow with a gasket on it, then knock up a bracket that you can attach a induction pipe onto that is fed through an aftermarket airfilter thats positioned at the front of the engine.....?
#21 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 06 July 2010 - 09:19 PM
bit like this, i know its crude but if you can see what im getting at.....
#22 skaterava
skaterava
  • 1,857 posts
Posted 06 July 2010 - 11:36 PM
Wait now i'm confused, my mechanical knowledge is limited so bear with me. The induction pipe would connect to the inlet located just behind an SU carb, where the airbox would connect to?
#23 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 07 July 2010 - 07:00 AM
thats correct, my idea is to take another "elbow", turn it upsidedown, rotate it 180degrees so the opening is facing the bulk head, somehow modifiy it to clamp down onto the "elbow" already fitted to the su carb, then run a pipe from that, to the front of the car with mabe a k&n style filter on the end, so you get nice cold filtered air straight to the carb.... if you get what i mean?
#24 skaterava
skaterava
  • 1,857 posts
Posted 07 July 2010 - 12:13 PM
I think i get it, yeah :D . I'd like to try my hand at building this, i'd like to see the effect it would have on a 998 engine.
#25 Burnard
Burnard
  • 3,350 posts
Posted 07 July 2010 - 03:15 PM
Why dont you just use a turbo plenumn and pipe it to the front, will be much better, it doesnt HAVE to be attatched to a turbo. :(
#26 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 07 July 2010 - 04:20 PM
It does :(
#27 Burnard
Burnard
  • 3,350 posts
Posted 07 July 2010 - 04:42 PM
Whats that then?
Anyway, thats what i had in mind when i said it lol
#28 Carlzilla
Carlzilla
  • 1,907 posts
Posted 07 July 2010 - 06:38 PM
Shh, theres a turbo hiding under there somewhere, i knows it :(
#29 skaterava
skaterava
  • 1,857 posts
Posted 07 July 2010 - 06:41 PM
Whats that then?
Where could i get some nice metal piping like that? And the elbows required, for that matter :(
#30 carts60
carts60
  • 1,007 posts
Posted 07 July 2010 - 07:01 PM
Where is everything hidden in that engine bay?? Mine is chock-a-clock with screen wash, brake fluid pot and a shed load of other bits and bobs.
That is a ruddy cool intake though.
