http://www.google.co...mp;ved=0CA8Q_AU
Need More Volume!
#46
Posted 26 July 2010 - 03:23 PM
#47
Posted 26 July 2010 - 06:57 PM
I don`t think the Amp is at fault at all! Just well, the fact that the Amplifier your using the power your sub woofers is playing low frequencies only i presume...Meaning your not hearing the frequency of the whine transmitted through the signal feed.
What i suggest you do.
Unplug the RCA leads from both amplifiers. Turn it all on, run the engine, see if you can hear an audible noise then. I don`t think you well to be honest with you.
If there is no noise, plug them back in to the amplfiers and unplug the cable from the head unit. If there is noise now, its a case of poor quality RCA cables passing over a part of the cars loom i can imagine. If there is no noise, the shield earth of the head unit is poor, refer to my previous post.
Also another little something you can try. Bang the rca lead with no splitter into the 6x9 amplifier.
Edited by Sam Walters, 26 July 2010 - 06:58 PM.
#48
Posted 26 July 2010 - 07:15 PM
go back and do it all properly...
Edited by minilester, 26 July 2010 - 07:16 PM.
#49
Posted 26 July 2010 - 07:24 PM
engine whine?..... bad earthing!
A bad connection somewhere no doubt, but i wouldn't rule out signal either.
#50
Posted 26 July 2010 - 07:59 PM
The amp used for the subs is not on low pass, the frequency is undoubtedly lower than the 6x9's but it's not pure bass.
If there is no noise, plug them back in to the amplfiers and unplug the cable from the head unit. If there is no noise, the shield earth of the head unit is poor, refer to my previous post. If there is noise now, its a case of poor quality RCA cables passing over a part of the cars loom i can imagine.
I'll try this next, but i have to admit the amplifier in question has been knocked about a bit. There was a month in which it was not fixed down in the boot whatsoever. Stupid i know
Edited by skaterava, 26 July 2010 - 07:59 PM.
#51
Posted 26 July 2010 - 09:01 PM
UNLESS youre really intent on buying another amp.
#52
Posted 27 July 2010 - 12:05 AM
#53
Posted 27 July 2010 - 12:44 PM
#54
Posted 27 July 2010 - 12:58 PM
and all power runs are as short as possible?
your not cable tying the cables together to "clear them up" and getting a little "cross talk" from the power runs?
wheres ya sub by the way and a capacitor really wont help... trust me....
#55
Posted 27 July 2010 - 09:44 PM
The earth at the head unit must now be checked. Unfortunately i'm only proficient with amp and speaker wiring, i'm a little confused at the mass of wires coming out the back of the stereo. How do i check the earth there?
#56
Posted 28 July 2010 - 11:50 AM
#57
Posted 28 July 2010 - 03:45 PM
i swapped head units the other day
and out of interest i took a ground loop isolator out to see if it made a difference
despite the new one being brand new, nothing changed (as in it still whined).
Edited by Carlzilla, 28 July 2010 - 03:46 PM.
#58
Posted 28 July 2010 - 07:28 PM
Make sure the RCA`s are plugged into the Amplifiers!
Unplug them from Head unit. Is the noise still there?
Oh and sorry for not replying lad, I do have internet on my phone so i can review the forums, however the silly browser will not let me select the correct input box to reply to posts.
Edited by Sam Walters, 28 July 2010 - 07:30 PM.
#59
Posted 28 July 2010 - 09:34 PM
i wouldnt bother messing around inside, it may void your warranty
No, if i remove the RCA's from either end (head unit or amp) the noise stops.
Edited by skaterava, 28 July 2010 - 09:35 PM.
#60
Posted 28 July 2010 - 09:42 PM
Try that and get back to me.
