Thinking Of Tuning A 998 Engine
Posted 27 June 2010 - 11:02 PM
A couple of people on here have opted for the 1061cc overbore and i was thinking of the same or possibly a bit higher, only downsize is the walls of the bore will be getting very thin therefore more vibrations etc etc. I would like it to rev fairly high, my 998 in my mini at the moment is slightly modified with 12G295 head, 1.3 or 1.5 roller TITAN rockers, uprated timing chain, electronic ignition and that revs to atleast 6500 or even 7000rpm. It has a lumpy tickover so could have a good cam in it.
If anyone has any recomendations then that would be great.
Thanks, Evan.
Posted 27 June 2010 - 11:08 PM
Edited by Mini-jon, 27 June 2010 - 11:09 PM.
Posted 27 June 2010 - 11:17 PM
Posted 27 June 2010 - 11:21 PM
Posted 27 June 2010 - 11:31 PM
Posted 27 June 2010 - 11:41 PM
I wouldn't mind getting a 1275 and doing a bit of work to that for performance gains. I can get a very cheap MG metro 1275 engine. I just like the idea of having a quick small bore engine capable of producing a relatively large amount of power.
Posted 28 June 2010 - 12:04 AM
Posted 28 June 2010 - 12:14 AM
Don't listen to all the chumps who insist a tuned 998 is a waste of time and money.
The 998 is quite tuneable for quite good money.
You don't even have to mess about with changing cranks really.
For good useable power a 998 is great, it'll take the revs and a lot of abuse on the road (mine does)
It'll keep up and even embarrass a lot of the 1275 (and bigger) engines.
You don't have to spend fortunes on it, just choose what to do wisely!
Remember, the 998 has been around a lot longer than the 1275 and more poeple have started their tuning careers, by using the 998.
The blocks are plentiful and cheaper than the 1275.
And the 998s are far more reliable!
Posted 28 June 2010 - 12:25 AM
Edited by george91, 28 June 2010 - 12:25 AM.
Posted 28 June 2010 - 01:46 AM
Posted 28 June 2010 - 08:21 AM
Have you considered a supercharger? this graph is for a completely standard 998 that has been supercharged:
Would stretch your budget but add a better head, cam or high lift rockers and better exhaust and maifold and you should be there
Posted 28 June 2010 - 09:30 AM
Despite this though, a 1275 metro engine can be found for £350 and they are brilliant and make good bhp and torque, just depends what you prefer.
Posted 28 June 2010 - 10:04 AM
Its encouraging to know quite a few people on here have 998's boasting big specs and that do give good power outputs.
I haven't really considered a supercharger as this would be a relatively expensive addition to any engine.
miniman92 - are your BHP figures at the flywheel. Also if you don't mind me asking how much did that setup cost you?
As i mensioned previously i can get my hands on an MG metro 1275 which i probably will in time purchase and then i can slowly build up a 998 in time.
Posted 28 June 2010 - 10:05 AM
Posted 28 June 2010 - 11:14 AM
