Rear Shock Absorber Fitting
Posted 27 June 2010 - 09:11 PM
Tried looking in haynes - can't find anything.
Steve
Posted 27 June 2010 - 09:30 PM
Posted 27 June 2010 - 10:24 PM
Dave
Posted 28 June 2010 - 08:54 PM
Was having a lot of trouble with noise from the back of the mini - have since found that it was lower mountings on the back of the drums not tight - but in the meantime I had backed the tops off a long way.
I thought there was a recommendation somewhere?
Steve
Posted 28 June 2010 - 10:28 PM
i cant remember on the standard shocks if they have a second nut as a lock nut like spax use,if not then use a nyloc nut or add a lock nut,there is no need to worry about torque settings or such,just nip it up with a good ring spanner(more feel than a ratchet).
hth
dave
Posted 28 August 2010 - 12:00 PM
Posted 28 August 2010 - 02:49 PM
Take a LONG length of rope/cable/something flexible and tie a bar to the end. Wrap it around the damper then turn the nut till the belt goes tight, then just tighten away.
I used an old seatbelt to get my ones off.
Posted 28 August 2010 - 03:28 PM
lol i think you have missed the questionAh, I got a trick for this.
Posted 28 August 2010 - 03:34 PM
Yes, Haynes do not state a torque figure, however this is from the Rover workshop manualAnybody got a link to a workshop manual or similar that states how tight to do the upper mount on the rear shockers?
Steve
SUSPENSION
Wheel nuts:
Alloy wheels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 Nm
Steel wheels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 Nm
Upper arm to front hub . . . . . . . . . . . . . . . . . . . . . . . 52 Nm
Lower arm to front hub . . . . . . . . . . . . . . . . . . . . . . . 52 Nm
Front hub to drive shaft - nut . . . . . . . . . . . . . . . . . . . 260 Nm
Front subframe turret bolts . . . . . . . . . . . . . . . . . . . . 67 Nm
Front damper to body bracket - nut . . . . . . . . . . . . . . 37 Nm
Front damper to upper arm - nut . . . . . . . . . . . . . . . . 48 Nm
Front subframe to body - nuts and bolts . . . . . . . . . . 25 Nm
Rear damper to body . . . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Rear damper to suspension arm . . . . . . . . . . . . . . . . 25 Nm
Edited by L400RAS, 28 August 2010 - 03:34 PM.
Posted 19 October 2024 - 06:57 AM
Does anyone know the nylock nut size that secures the lower rear shock to the back of the drum? mine keep backing off leading to a knocking noise, planning to replace the bushes and nuts. cheers,
Posted 19 October 2024 - 07:12 AM
3/8" UNF (lower stud thread on the arm).
The upper Pin originally was 3/8" UNF. Some still use this size, but most have gone metric and will usually be M10 in either 1.5 or 1.25.
For anyone reading this thread in future, looking for information about how tight to do up the upper nut (or any shocker nut for that matter), there is no torque vale for these. They are done up, in the case up the upper rears, to the end of the thread. Below that is a plain shank that has the correct preload distance for the compression of the rubbers. For all others, they have a crush tube in the rubber, the nut (and large flange washer) are done up until they seat very firm on the tube.
Posted 19 October 2024 - 09:46 AM
Just to add to Spider's comment, I lost one of the top nuts on a new pair of KYB shocks. It was a metric size but of an unusual pitch. Had to take the shocker to a local Fixings company to match the metric pitch.
