I've always hated how naff the engine bay looks, so over the last fortnight, I've done something about it.
Hopefully this will inspire others to do the same! Its easy, just takes time and patience.
This is how it looked before I changed the head, and I had a failed attempt at using engine gunk:
When it's this bad, engine gunk just isn't worth it. Thinks get cleaner, but not better. Just look at that bulkhead! Everything's just a mess:
On Monday, I dropped the grill off, and removed the spots and fogs. It's also important to bag and tag everything you take off. Even if you know what you're doing:
I then took the time to get as much oil and rust and gunk off the block as possible:
I also took out the bulkhead foam as it looked awful, trapped water and did nothing for sound deadening whatsoever:
Then I got busy with the newspaper:
There's not much block left!
