What Is A "short" Engine ?
5 replies to this topic
#1 MiniMonty
MiniMonty
  • 1,802 posts
Posted 24 June 2010 - 02:48 AM
Hi all,
I've been thinking about a new engine recently (because I have a fatal half moon oil leak and I reckon
that if I have to have the engine out I may as well put a better one back in) so I've been cruising around the classifieds, eBay etc.,
Now and then I see a "Short" engine advertised and I have no idea what that means.
Can someone educate me please ?
Best wishes
Monty
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 June 2010 - 04:01 AM
A short engine is usually just the engine block, crank, pistons etc, no Head and no gearbox and usually no flywheel either.
#3 MRA
MRA
  • 7,607 posts
Posted 24 June 2010 - 06:47 AM
Some will not supply new camshaft, cam followers, pump etc.... opting to simply supply a block, crank, conrods, pistons and bearing shells.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 24 June 2010 - 11:53 AM
The 998 engine is about 1/4" shorter than the 1275 engine................
But yes - usually the description 'short engine' means a complete block assembly - less head, sometimes less timing cover/timing gear/camshaft etc.
#5 MiniMonty
MiniMonty
  • 1,802 posts
Posted 24 June 2010 - 12:08 PM
I geddit...
It means an engine that's short of a few bits !
#6 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 24 June 2010 - 12:16 PM
I geddit...
got it in one monty aha.
i never knew what a 'short' engine was at first either until sometime last year lol
