Overheating - Bigger Radiator?
Posted 22 June 2010 - 06:52 PM
at that temp the oil temp had risen to 110deg c when the dash alerted me to the oil pressure then dropping.
i was cruising on the motorway off-vtec. 60 - 70mph.
i have 3 fans on the radiator - 2 pulling and one big to push.
does anyone else have this problem?
does anyone else have a solution? bigger radiator?
i have not yet ventured to a track day but would assume it will kill itself if. i did buy the race spec kit, you would think it would cope...
Posted 22 June 2010 - 07:11 PM
Posted 22 June 2010 - 07:31 PM
Is that right? try all in the same direction, ie pulling
David
Posted 22 June 2010 - 07:40 PM
David
there is no room for my 3 on one side. i had to use the bigger on one the push side...
hmmm
Posted 22 June 2010 - 09:48 PM
David
Posted 23 June 2010 - 05:57 AM
Posted 23 June 2010 - 09:11 AM
Have you got a bleed on the radiator? if you have try raising the back of the car and bleed the rad out. If not just tap a 6mm hole in the top plastic bit of the rad and use this as a bleed hole and use a regular M6 bolt as a bung, just be careful not to overtighten as you're only tapping 1-2mm of plastic, I used a rubber washer under a regular washer to ease the amount of tightening required.
Where is your temp sensor placed?
You might want to try filling water into your bleed hose on the top hose fitting of the engine (careful not to overfill above your expansion tank level), just to make sure you have fully filled the block, thats why I went for two filling points either side of the thermostat to ensure the block was getting filled at the same time as the coolant lines and radiator.
Posted 23 June 2010 - 09:16 AM
Allan
Posted 23 June 2010 - 10:13 AM
one other question, are you guys running a sealed blukhead? not venting out into the air with no rear windows etc. im wondering if its the bulkhead thats trapping hot air in the engine bay.? (i am venting a bit on the boot lid)
Posted 23 June 2010 - 10:47 AM
Posted 23 June 2010 - 11:19 AM
Posted 27 June 2010 - 04:16 PM
i started of with zcars's solution. just one big fan pulling air though the standard (polo ?) radiator. this failed the IVA due to it overheating at idle.
i added a smaller secondary fan to go next to it still pulling. this passed the IVA at idle and the fast idle test. but i did hide to the tester the fact that the dash was alerting me again right near the end of the test. i drove it for a while noticing that in traffic it would overheat. so i added a third to push the air though the small space left below the small fan.
All this didnt do much at the time hence starting this thread.
Today i couldnt be bothered to watch the football and went about having a go at flushing and bleeding up the system again.
Nothing major found, clear water so no rusting etc. i bled back up again and went for a drive. it behaved exactly like it did before, over heating after a while cruising.
its been 30 deg c outside temp today so it didnt take long to show.
I took all the fans off and replaced them on the rad, one massive one and a small one pushing this time, and the med size one in the gap left by the small one but on the other side pulling. there is no fan fighting for another fan now, they all have clear air and are all spinning the right way.
on my test drive i noticed that it still got very hot, but didnt overheat. 94-96 deg c oil was 100 to 102 deg c. it is a hot day for the UK so this might have solved it. i would like to have seen it stay in the 80's though....
i am using a standard bonnet, not the aero type zcars sell. i wonder if that make a good difference to cooling as it should do with the downforce?
Posted 27 June 2010 - 05:26 PM
Ed
Posted 27 June 2010 - 05:39 PM
Maybe check the thermostat outside of the car in some warm water to see if its working properly .
Maybe your front grill is too restrictive .
Maybe the engine going a bit lean on idle ,
Just throwing some ideas
