Weber Manifold
Posted 20 June 2010 - 02:25 PM
i want to fit a weber to my mini i have a highly tuned 1293 should be about the 100bhp mark with a longman race head 286 kent cam fully lightend and ballanced big end and mega jolt plus a lot more.
the question is which of the dcoes should i use and what is the best manifold to use concidering i don't want to cut the bulk head/put in a weber box i know this won't give me the best power results but it is my choice, what lengh is a swan neck manifold and are there alternative short manifolds
Posted 20 June 2010 - 03:31 PM
They are very inefficient,you also need rampipes on webers so there wont be much room for these and a decent filter arrangement.
If you dont want to make a bulkhead box,dont bother fitting it,whats the point if it results in less performance than a standard su setup?
dave
Posted 20 June 2010 - 03:40 PM
Posted 20 June 2010 - 04:11 PM
Should also make a few extra ft/lbs of torque over the Weber too
Posted 20 June 2010 - 05:23 PM
Posted 20 June 2010 - 05:30 PM
Posted 20 June 2010 - 05:38 PM
Oh yeah and the hiff44 is only really good for 100bhp and my long term aim is 120bhp
Edited by 1293sleeper, 20 June 2010 - 05:42 PM.
Posted 20 June 2010 - 05:47 PM
Posted 20 June 2010 - 06:00 PM
Posted 20 June 2010 - 07:47 PM
Posted 20 June 2010 - 07:56 PM
Posted 20 June 2010 - 07:59 PM
Posted 20 June 2010 - 09:47 PM
The vizard book shows a 1435 fully worked motor putting out around 117hp with a hs6 su,that flows less than a hif44.with the weber on a decent 5" manifold it was about 121 hp.,the su gave more power than the weber up to 5000rpm,and was only 4hp down at 7000rpm.
on a comparison on another 1400 motor,there was only about 1hp between the hif and weber 45 on a good manifold.
hif44 flows 240cfm,unmodified
weber 45 flows 242cfm,unmodified.
a test vizard did with different manifolds on a 40dcoe,show a 5hp loss at top end between a swanneck and a 5" manifold.
The torque curve was was the worst of the lot,a hs4 completely outperformed it.
so if your not bothered about performance,fit a swanneck.
seeing as you have made mods to the engine to improve performance,this seems a bit crazy.
The 40dcoe on a good manifold is really only good for 80hp,similar to a single hs4,if you want 120hp you need a 45 or a hiff44.
hth
dave
Edited by Dave33, 20 June 2010 - 09:55 PM.
Posted 20 June 2010 - 10:01 PM
ill get some pitcures an measurements for you mate
ill try do it tomorrow for you, pm me you email address so i can try send some pictures over
sat
AS SAID HIS CHOICE TO RUN THE SWAN NECK MANIFOLD. IF YOU HAVNT GOT INFO DONT ANSWER!!! HE WANTS A SWAN NECK MANIFOLD NOT PEOPLE TELLING HIM NOT TO RUN ONE!
