Micramini - My First Conversion
#76
Posted 12 August 2010 - 06:24 PM
coming soon... watch this space
#77
Posted 12 August 2010 - 09:19 PM
took around 100 pics to put into a wiring tutorial, should be able to whack that together some time at work next week for you budding converters.
wiring it the second time i relised again just how simple the wiring actually is, made even easier if you use many of the existing mini fuses!
all will be revealed soon, but for now here is some taster shots:
not as scary as it looks, honest guys! Can see here where i have pretty much welded up every hole in the bulkhead (no more leaks hopefully)
don't worry, i have a fglass dash that will cover all this messyness.
a slight tidy up needed, and some decent rad hoses, any ideas?
5 gears baby, never seems to get old...
#78
Posted 13 August 2010 - 10:35 AM
Under the bonnet's looking really tidy, you should be really proud of that. You could just buy some lengths of silicone hose to replace the rubber ones.
*edit: I can't spell.
Edited by evansisgreat, 13 August 2010 - 10:36 AM.
#79
Posted 14 August 2010 - 11:17 AM
Isnt that fuel filter supposed to be conected to something, like, erm, the fuel line?
#80
Posted 14 August 2010 - 11:26 AM
#81
Posted 17 August 2010 - 08:51 AM
Has the ground clearance been reduced by much ?
Cracking build.
#82
Posted 17 August 2010 - 02:40 PM
Maybe we won't have to keep pulling over on the way home from L2B to put your carb back together
#83
Posted 28 August 2010 - 05:51 AM
#84
Posted 03 September 2010 - 01:31 PM
#85
Posted 03 September 2010 - 01:32 PM
#86
Posted 03 September 2010 - 02:17 PM
#87
Posted 03 September 2010 - 04:08 PM
#88
Posted 03 September 2010 - 04:14 PM
sorry guys, been a bit busy, will have an update for you tonite tho
Is it sad that this post is almost enough to make me stay in tonight?
Yes it is. I know.
#89
Posted 03 September 2010 - 04:18 PM
What structural properties do the triangle sections on the left and right sides have (the ones connecting the wings to the firewall, just in front of the tower bolts)
The problem i am having is that the left hand one is in the way of the alternator, what are my options here?
thanks
#90
Posted 03 September 2010 - 04:19 PM
haha, i would go out if i were you mate, i can't take pics until my dad brings his camera home and im just about to go out to work now!sorry guys, been a bit busy, will have an update for you tonite tho
Yes it is. I know.
may have to be tomorow morning that i do a pic update
