awesome project mate... loads of ideas now
still unclear on what to do with the piston though?
Edited by finch661, 19 June 2010 - 10:40 PM.
Posted 19 June 2010 - 10:40 PM
Posted 19 June 2010 - 10:42 PM
yep this is how i did it,and finish with a fine file,also make sure you loctite the butterfly screws in.I've done the spindle mod, but differently.
Mr Vizard says to slim it down, its quicker to cut the top half (thredless half) away and file it down flat. Takes 1/8th the time and give the same results. Makes the carb much perkier but you will need a new needle.
Edited by Dave33, 19 June 2010 - 10:47 PM.
Posted 19 June 2010 - 10:50 PM
Never had any probs with idle,sounds like butterly not closing as far as should,the spindle has no effect on idle it merely supports the butterfly.
is all you got to do to piston is put a chamfer on either side,not much,the vizard book explains what angles,as long as its close it will help ,
but it wont make an awful lot of difference,
read the section a few times to fully understand whats needed,
hth
dave
Posted 20 June 2010 - 01:34 AM
Posted 20 June 2010 - 08:30 AM
Edited by PIGEONTO, 20 June 2010 - 08:31 AM.
Posted 20 June 2010 - 08:40 AM
Posted 20 June 2010 - 08:52 AM
Well you cant question results like that. Not knowing about racing I hadnt considered that aspect.I believe it's also born through the racing scene, where you are restricted to run a control carb but are allowed to modify the internals
The CFM raise is in the region of 20-30% over the original, well worth it in my opinion. And mine certainly revs a lot easier than on a standard carb and picks up much quicker when on the motorway to overtake.
Posted 20 June 2010 - 09:14 AM
Posted 22 June 2010 - 10:32 AM
