Left Tie Rod Bent
16 replies to this topic
#1 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 18 June 2010 - 09:18 AM
got a bent left tie rod, i assume cars tracking was set up with this.. do i need to replace the rod??
#2 Pooky
Pooky
  • 5,691 posts
Posted 18 June 2010 - 09:34 AM
Never assume anything!
If the car drives ok and you're not seeing any irregular tyre wear then you're probably ok to leave it for a while. But if I were you next time you come to change the tyres at the front, replace the bent tie rod (maybe both if you're feeling flush) and all the bushes for both rods and have the tracking re-set :thumbsup:
#3 E-Tizzle
E-Tizzle
  • 901 posts
  • Local Club: Essex Mini Club
Posted 18 June 2010 - 11:14 AM
both of my tie rods were bent quite badly.
so i replaced both of them just incase.
its been off the road so i didnt have a chance to 'feel' if it was driving badly.
but the haynes says replace immediately and people on here have said chance them.
i bought up rated 'rally spec' ones. and put poly bushes on there because they will last longer and i cant see these ones bending.
they are about 5 mm thicker (i think) cost me £20 plus a £5 for the bushes. altough i found a website were the poly bushes are about 80p each.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 18 June 2010 - 07:18 PM
Change it, better to be safe than sorry, you really cannot tell what over damage may have been done to it.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 June 2010 - 07:49 PM
Take it off and straighten it! And yes - you would be best to then check the tracking.
#6 Boycie
Boycie
  • 1,978 posts
Posted 18 June 2010 - 07:54 PM
I'm sure people will moan at bmcecosse for saying 'straighten it' but that's what I normally do- IMO it's absolutely fine to do that. Also, especially when Minis were everyday cars, I'd say a great many (most?) of them were running around with a slight bend in the tie-rod.. with no obvious problems!
I've never been a fan of adjustable rods on a car that is purely used on the road, they're just not necessary unless it's a track car.. but again, many will argue! If the worst comes to the worst (eg the threaded end shears when you remove it) new standard replacements are not expensive!
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 June 2010 - 07:55 PM
Exactly Boycie - well said!
#8 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 June 2010 - 09:09 PM
Yes if the budget is tight and you have no reason to fit upgrade parts then by all means go ahead and straighten the tie rod. But sometimes the original parts are just not up to the job. an awfull lot of people on this site ask questions about bent tie rods! so why not upgrade to heavy duty when it seems to me the standard ones cant cope with todays driving conditions. Are we driving our minis on poorer roads? Are we driving faster? Ultimately the choice is yours.
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 June 2010 - 09:16 PM
They only get bent because some fool puts a jack under them ! Or perhaps by reversing hard on lock against a kerb!! Unless for extreme off road use - the standard tie bars are fine.
#10 Burnard
Burnard
  • 3,350 posts
I still have my set of origional ones if you want them :)
#11 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 June 2010 - 09:20 PM
Mine were straight untill i had to make an emergency stop on an uneven surface. Result!!! Bent tie rod!
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 June 2010 - 09:21 PM
Hard to imagine how - since they would be in tension due to the braking force!
#13 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 June 2010 - 09:35 PM
Sorry Bmc. I dont meen to be negative, and i agree the rods are obviously under tension when braking, but what can i tell you. thats what happened!! Maybe im just unlucky.
#14 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 18 June 2010 - 09:43 PM
I can't honestly see how they would bend under braking?
I've seen the front mounts on frame break before any further damage is caused.
Although the uprated adjustable ones look good , they really need to be set up properly as well otherwise theres no point in fitting them.
Standard ones are generally fine for even the most spirited road use.
As already said the most common cause of damage is careless jacking.
#15 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 18 June 2010 - 09:54 PM
Sounds like mine had been bent prior to the heavy braking episode. But the car was only finnished one month before so i know it was straight at mot time. anyway im sorry if I misled any one.
