Diy X-flow Head
#46
Posted 15 June 2010 - 07:20 PM
#47
Posted 16 June 2010 - 09:15 AM
that is awsome!
what happened to the head in the end?
I sold it to a friend in our club who used to work for the guy who owned and raced the rallycross car that the head came from, he remembered me from 20 years ago which shows it's a small world. I showed the head to a few engine builders over the years and the general consensus was that the head worked brilliantly for their time (mid 80s) where maximum flow was all that was considered but a modern head would probably be as good at maximum valve opening but would also give better flow and drivability at small to medium valve openings.
There was also thought to be an issue with the head being porous between the water jacket and the new ports as the heads had not been heated correctly when welding in the steel ports, not a problem with a race engine where they are doing 20 minutes max running in a race but possibly a real problem on a road engine.
#48
Posted 17 June 2010 - 07:48 PM
Have you got any closer pictures of the manifold and the clearances between the rockers?
I know it's a lot to ask, but is there any chance you could send me all the pictures you have of the head/manifold?
I can't believe you owned this!
#49
Posted 19 June 2010 - 02:53 PM
Pogie I stumbled across the pictures a while back but haven't been able to find out any more info on the head/mod. Unfortunately it's not mine.
I might have some more photos hiddedn away somewhere, they were taken 20 years ago and I scanned the best ones. The space between the ports for rockers was one of the reasons for not using the head as there would have been clearance issues for roller rockers.
#50
Posted 31 August 2010 - 08:56 AM
#51
Posted 31 August 2010 - 04:44 PM
he was doing a conversion but its shelved at the moment, money might affect that though.
#52
Posted 31 August 2010 - 05:40 PM
wonders outside into garage . . . .
#53
Posted 01 September 2010 - 03:29 PM
would you do an 8 valve or 16 valve? oh and it might be worth turbo or supercharging wonder if the Jcw mini supercharger will work?
that would be a seriously hybrid mini
#54
Posted 01 September 2010 - 06:26 PM
#55
Posted 01 September 2010 - 06:33 PM
can anyone tell me if this would have enough torque holding the head on with only 7 bolts ? surley it would leaki have been thinking the one thing that really bugs me about the a series head is the carb being at the back, and getting a 8 port or xflow is not cheep at all.
i was wondering i am asuming the chambers extend to the front of the head, could you machine holes in the front, weld up some form of mating surface for a custom manifold and block up the holes at the rear. if so im going to try it with my spare 12g940,
look at this period x flow head for example
i am aware that that is a alloy casting but im sure the same principle applys face off the front, bolt on the mating surface plate. and block up the rear
#56
Posted 01 September 2010 - 06:57 PM
#57
Posted 01 September 2010 - 07:00 PM
#58
Posted 01 September 2010 - 07:30 PM
#59
Posted 01 September 2010 - 08:39 PM
#60
Posted 02 September 2010 - 07:37 PM
