Its all done, I started it up and did the timing with the strobe, Needs the carb done and the tappets set, but its runing, and no smoke. I took it for a scud this morning and its not far off, I reckon with the carb sorted and the tappets adjusted to 14thou its going to be spot on. Its a bit wet in Inverness today so its a bit slippy out there. Comes on cam at 2600revs. Im not allowing it to rev beyond 4k and am only useing about 1/4 throtle for acceleration. It is turning heads, took it through the town and people were literally stopping to look and listen, The sound is awsome. Very lumpy below 2500revs and then a sweet spot before all hell breaks loose at 2750. Very tempted to let it go, But Im going to have to be good for a week or so untill its done a few hundred miles.
Oil presure at tick over. (1200rpm)
The tick over is quite high untill it loosens up a bit, I will set it to about 1000revs once its run in. I have a vidio of it runing but my broadband is very slow today for some reason so it wont upload to photobucket. will try again later when all the porn junkies have logged off.
Edited by AndyMiniMad., 27 February 2011 - 05:46 PM.
