First thing I did was to cut open the breather tube and make a small plate to weld on.
Once the welding was cleaned up and it was given a coat of paint it looked ok.
Ive temp fitted it for now just to keep the timing gear clean.
Next I fitted the flywheel housing.
And then this red ring thingy.
Lightened flywheel from Mini Spares, Clutch and top clamping plate thing.
Now im not sure about this but some folk reckon you can get an extra 10 BHP with this colour.
This bit was next, All cleaned up of course.
Nasty bell housing. With the wrong type of plunger, but the other bits will be fine after a good clean.
Ta Da!!!
And a coat of primer on the cover.
Then the water pump, Mini Spares high capacity type.
Sorted.
Edited by AndyMiniMad., 13 September 2010 - 04:53 PM.
