Wide Ratio Gearbox And 1380 Engine Build
#316
Posted 26 November 2011 - 04:33 PM
#317
Posted 26 November 2011 - 11:52 PM
#318
Posted 26 November 2011 - 11:55 PM
#319
Posted 27 November 2011 - 12:09 AM
May have to take my block up to them, at that price!
Im starting to think I should charge commission...
But if you do come through to the capitol..give me a call mate...I'll pay for lunch!!
Edited by AndyMiniMad., 27 November 2011 - 12:16 AM.
#320
Posted 27 November 2011 - 11:22 AM
I did most of the block cleaning my self to be honest..The gearbox case was chemicaly cleaned by them..and ill bung a couple of pics of the quality of the clean next week when I get it back.
How did you go about doing this Andy? Did you wash it all through with paraffin or something?
#321
Posted 27 November 2011 - 03:44 PM
#322
Posted 28 November 2011 - 09:42 PM
0.05mm...or 0.00197" in old money.
All in and torqued down.
Pistons all fitted..
Edited by AndyMiniMad., 28 November 2011 - 09:43 PM.
#323
Posted 29 November 2011 - 04:46 PM
New heater take off valve fitted.
#324
Posted 01 December 2011 - 04:51 PM
old one!!
New one!!
New end float...
Perfect...
#325
Posted 04 December 2011 - 09:17 PM
Yep. your quite right! Two sets of feelers one on each side will be required for a totally accurate reading. I actually used my DTI to measure the gap.... Sorry if I misled anyone..Really you should use 2 feeler gauges to measure this, one either side of the crank. The actual clearance will be a thou or so tighter measuring with only one gauge, due to the primary gears clearance on the crank.
Edited by AndyMiniMad., 04 December 2011 - 09:20 PM.
#326
Posted 04 December 2011 - 09:45 PM
studio 2 ftwAnother day at work!! Mondays Eh, Never mind only 4 more days till the weekend.. Oh if any ones interested this is where the gearbox came from.
It didnt look to bad when i bought it, paid £250 eight years ago.
Started to strip it down thinking it was gonna be a quick restoration. OHHHH BOY was i wrong.
Oh time for tea.
Back with more later......
#327
Posted 11 December 2011 - 05:34 PM
Ive redone the the diff preload which is a pain in the arse to get right...but Iv got it to within a thou of perfect...gap plus gasket was 0.01" Im hoping that the hylomar will make up the difference..
The preload should be 4 thou according to the Minispares web site...??
Oh! and I got Haggis's block back from having a fresh hone...so I gave it a quick coat of red...
This gearbox is next for a rebuild and will go under the other 1380 engine...Its all getting a bit confuseing trying to build two engines and three gearboxes at the same time!!
Edited by AndyMiniMad., 11 December 2011 - 05:48 PM.
#328
Posted 17 December 2011 - 12:17 PM
New core plugs fitted..
Timing gear fitted...
I did time the cam in with my DTI..although it was not really nessessary..
If your interested on how its done then here is a link to my Cam timing Thread..
http://www.theminifo...l=&fromsearch=1
Edited by AndyMiniMad., 17 December 2011 - 12:19 PM.
#329
Posted 18 December 2011 - 12:12 PM
The depth turns out to be 1.008"
Next I measured the thickness of the gasket..
Its 0.032" which when fitted will sqwoosh down to 0.03"
The thickness of the steel rule is 0.08"
And the idler gear itself is 0.686"
So now we can calculate the shim thickness required by adding the depth of the housing to the thickness of the gasket
1.008 + 0.030 = 1.038"
Next we subtract the thicknes of the idler gear 0.686" and the thickness of the steel rule 0.08" from 1.038"
1.038" - 0.686" - 0.08" = 0.272"
So this is the thickness of the shims required to fill the rest of the gap..But we need and end float of 0.004" so Im looking for a couple of shims at 0.268"
Found a couple that are perfect...it doesnt matter if one is slightly thicker than the other so long as the total thickness adds up to whats required..
So thats me ready to put it all together..
#330
Posted 21 December 2011 - 05:32 PM
Transfer housing fitted and new clutch..
This is how I lock the flywheel..
Head on and thats it almost ready to refit..Just need to figure out the speedo drive...Guessworks web site will be getting another hit.
